Brushed look on bumpers?????
Thinking of trying to match the machined look on the lip of my wheels. Is there anything I can do to my existing chrome bumpers to get this look?
Posted via Mobile Device |
Re: Brushed look on bumpers?????
I have seen some guys use a product called, PlastiDip. They use their version of clear coat and it gives chrome a satin/matte finish. You might want to check into that.
You could sand your bumpers with 400 grit, and give it a few good coats of clear.
drive right behind someone on sanded roads
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
DA w/some 180 & ScotchBrite
I would use a red scotch brite pad, and scuff it really good length-wise. Don't get into it too bad and you won't need to clear it or anything.
My 68 cougar restomod build:HERE |
Thanks guys wasn't sure if sanding would work and diqdn't want to risk ruining it.
