56 Mild Custom Build
Here's my 56 Chevy that I'm restoring.
Truck the day I bought it on Feb 12 2013 ![]() ![]() ![]() The next day making sure the small block runs ![]() Pulled the engine n trans ![]() Day 3 ![]() ![]() Driver door rust ![]() Lower door skin installed ![]() Posted via Mobile Device Posted via Mobile Device |
Re: 56 Mild Custom Build
Shaved the firewall
![]() One piece window installed the right way. Rolls up and down nice and smooth and the glass dosent rattle ![]() ![]() Driver and passenger step panel installed ![]() Stripped the dash found a ding with a hole. Pulled out the ding welded up the hole. Alittle filler I'll sand it later ![]() Posted via Mobile Device |
Stripping the body down to metal
![]() ![]() Making the pattern for the door panels ![]() Mocking up the kick panels ![]() Posted via Mobile Device |
Mocking up the subwoofer box. Keeping the stock gas tank location and bench seat but still want nice deep bass!!
Gas tank cover, the base for the sub box ![]() Subwoofer box mock up going with 2 JL Audio 6w3v3 in a ported box, 6x8s rear, 6.5 componets and 4 inch center speaker for the front. All will be powered by a JL 5 channel amp. ![]() Still working on mocking up the audio.Got to figure out where to put the 6x8s. Box will be covered in black suede. Posted via Mobile Device |
Here's my old Mercedes I built, simple and clean
![]() And that's where I'm at with the truck now. Hopefully it will be done by the end of this month. Fingers crossed Posted via Mobile Device |
![]() Join Date: May 2010
Looked like a pretty nice BBW truck to start with. You are making a lot of progress in a short time, Keep the pics coming.
Looks like a nice build. Do keep the pics coming.
What kit did you use for the one piece windows? Kim |
All the kits are the same. They come wih the glass and the window channel felt and they just tell u to take out the wing window and install the channel felt. The problem with that is there's no metal channel for the felt to to glue to so it just hangs there loose in the front of the glass. Also where the window attaches to the regulator is to short so the window always pops out when rolled all the way down. And since the one piece window now is angled in the front ( the original window is vertical ) u have to angle the original metal channel back a few degrees and also fab up a new metal channel in the front of the door and angle it with the rear channel. There is no kit out there that works right u have to fab it up yourself. If any one lives in the Houston area I can do it for u.
![]() Join Date: Jul 2009
Nice start, and tremendous progress for less than a month. What part of the Houston area are you in?
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now )2001 GMC Sierra K2500 |
NW Houston. Truck is being built at my "shop" in Tomball
Driver fender. Pulled and hammered out a few dings. Welded up some cracks. Fabed up a missing brace. First coat of bondo about to block it out.
![]() My dad blocking out the fender and door ![]() ![]() Me mocking up the AC. AC and heater lines will be routed thru the kick panel and behind the inner fender. ![]() Daddy's little helpers ![]() Yep I need a truck. Getting the board for the door and kick panels ![]() Stripping the tail gate ![]() Posted via Mobile Device |
#13 |
Look at all the pretty colors
![]() Cleaning the frame getting ready to paint it found this under a pile of grease. Wtf? Why would some one do that? Maybe for a big block? ![]() Posted via Mobile Device |
#14 |
Looking good.
Kim |
#15 |
New parts came in today
![]() Bondo work done on passenger fender. Just sprayed it with ecthing primer. Set it aside, will do final primer and block sanding once mounted. ![]() Installed passenger lower door hinge panel, original one was pretty mangled. Install door to double check and see if I lined it up right... Which I did ![]() ![]() Posted via Mobile Device |
#16 |
I love getting new parts.
The fender looks good. Kim |
#17 |
#18 |
Lining up the door
![]() Put the fender on so a I can weld on the lower fender brace I fabbed up ![]() Posted via Mobile Device |
#19 |
Coming right along - looking good!
#20 |
Looks good.
The real trick is getting it all to line up back on the frame. Kim |
#21 |
Looking good
#22 |
Got the frame painted and the cab under coated. Finally the cab is in the frame so I can finish up the body work and get it in primer.
![]() ![]() ![]() Posted via Mobile Device |
#23 |
Looking good. Great work and getting it done quickly. Youll be done in no time.
#24 |
The frame came out real nice.
Kim |
#25 | ||
| Bookmarks |
