Old 03-10-2013, 12:32 PM   #1
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Front Rotor Balance??
I have been chasing a a vibration in my truck and have been focused on the rear end. I have been driving my truck quite a bit lately and have noticed that in addition to the rear end vibration that sort of pulsates (vibe... vibe... vibe...) I have a "shake" in the whole truck at anything above about 60 mph. My question is this, Is there a way to check the balance of front brake rotors?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-10-2013, 02:22 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Front Rotor Balance??
I had a problem like this years ago and it was a combination of a bad tire
and a bad wheel bearing.
And a totally worn out front end...
IMHO, you may want to get her off the floor and shake down the whole works...
(front end parts, wheel bearings...) plus check your tire pressures and rotate your
tires to check for a broken chord, missing wheel weight, etc.
Are the rotors new? Were they turned prior to install?
... my 2 cents...
ETsC10 is offline   Reply With Quote
Old 03-10-2013, 02:33 PM   #3
C10_ustacould
... my 2 cents...
All good observations...
Front end and wheels/tires are all new components. The rotors I got from a board member and where new but had been stored for many years. I am going to investigate the rotors/bearings as well as the wheel/tire balance.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-10-2013, 02:46 PM   #4
BMERDOC
BMERDOC's Avatar
To answer your question, no, there is no way to check rotor balance. If you can't feel a direct vibration in the steering wheel then you are correct to assume that the vibration is coming from the rear. If its a pulsing vibration I would consider looking more into a driveline vibration like a bad u-joint or an driveshaft that is tweaked or needs a rebalance. Is the driveshaft a one piece or two? If its a two piece then the center bearing could be to blame also. I wish you luck in finding your problem.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-10-2013, 03:18 PM   #5
C10_ustacould
I am considering changing the name of my build to Shake, Rattle, and Roll! I believe there are several issues going on at once. I'm just going to have to try and isolate them one at a time and correct them.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-10-2013, 08:06 PM   #6
Sammy
Very likely you threw a weight off the drive shaft causing an outta balance condition.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-10-2013, 08:15 PM   #7
C10_ustacould
Drive shaft was recently balanced, and all of the weights are there. Thanks for the suggestion!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-10-2013, 08:53 PM   #8
Fldawg
Fldawg's Avatar
Hey buck new tire can be bad, do you have your old set put them back on and see if it does it and did it do it before new tires, just a thought
Fldawg is offline   Reply With Quote
Old 03-10-2013, 09:00 PM   #9
C10_ustacould
Just sold the old wheels and tires yesterday, but it had the issue with that set up too.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-10-2013, 09:17 PM   #10
Fldawg
Fldawg's Avatar
well try this jack up the rear tires, crank it up put it in drive and see if you can feel the vibration, if it does drop the driveshaft see if it makes it quit, this will elimanate the probelm with the rear end. this is how i solve probelms with buses that have 3 to 4 drive shafts in them, try it you don't have nothing to lose. Oh by the way if you can make it theres a show at rosemary beach on the 23rd, good laid back show but it needs more trucks.
