![]() Join Date: Dec 2012
Cab mount bushing replacement without lifting cab??
Is there a way to replace cab mount bushings and hardware without removing the cab from the frame? Could it be loosend on all sides and lift and support carefully and evenly enough to squeze new ones in? Should the core support mounts be done at the same time?? I don't have a space to lift the cab off or do "major work" without upsetting the HOA.
3 of them look good but there is one that is trying to split and escape. Thank you in advance for all suggestions. Vince
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Re: Cab mount bushing replacement without lifting cab??
subscribed because in my peanut head i was thinking they would just "come out" when i wanted to swap them.
People know me
Yes, just get a floor jack and a piece of 4x4 and lift the cab with the jack and put the new ones in, I believe the core supports come in the kit.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
Same thing, I did mine with a floor jack and a block of wood. You can get a good half inch of space, which is plenty to change the mount.
I only did the 2 front cab mounts under the floorboards, the rest still look pretty good.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Ordering poly mounts today.... Install in 6 months when I get permission from the boss
Are there better or worse mounts? I will probably go to LMC or GMC Paul.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 03-15-2013 at 12:02 PM. |
I got my prothane mount kit off of ebay for 60 somthin bucks shipped. That was the cheapest route, I only wish I would have got new bolts since I'm doin a cab swap. Anyway Im sure the old bolts will be fine, the vender was streetrays inc. out of Tx.
Doin my cab and motor swap as we speak........
Victory will only be achieved through superior firepower and trusting in the Lord. SOLD 68 C-10. http://67-72chevytrucks.com/vboard/s...d.php?t=560975 SOLD 2000 Silverado...http://67-72chevytrucks.com/vboard/s...=1#post6492671 87 V-10 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=643898 |
Yep x2, block of wood, floor jack. I replaced all four and the core support. i ordered rubber ones to replace. They were not that difficult. A lot of mine crumbled out.
Note the bolts in the front two are welded to the floorboard in the cab. Air chisel works wonders
#8 | |
It's all in the timing
I replaced mine with poly mounts,improved the handling(less body roll)but you feel every vibration and pebble you hit.
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
Thanks all for the advice and suggestions. I only found the rubber ones. Couldn't find poly. 1970 Bowtie, thanks for the input, after reading your post, and wanting a smoother ride, I am glad I didn't find the poly.......
OK updates when they are in . Vince
Hmm strange. I'm the 2nd owner and mine had a tac weld on the bolt head to the cab floor.
Neither one of my trucks had them welded in.
Longhorn 70. A little FYI..... The nuts on the FRONT mounts are locking nuts which means the inside of the nuts where the threads are, are kinda triangle shaped. When tightened onto the bolt they lock on. TAKE YOUR TIME!!! and do not be suprised if you snap one of the bolts. I snapped both fronts on mine when i changed them, but they were pretty rusty. |
#13 |
I wouldn't go with poly mounts anyways. Got my kit from GMCPauls and the parts were good quality and fit, might have to reuse your top shims for the front cab mounts. Did the method as described above and maybe took an hour at the most.
Gary Slowly looking for my next 67-72 truck |
#14 |
![]() Join Date: Mar 2011
My son just did all of mine using a jack and 2x4's as others have said. Bought a poly set off the parts forum here and no, they don't come with bolts but they are easily found at your hardware store. Took him longer to go get the nuts and bolts than to do the job (about 30 minutes).
Rubber or poly? I would have been fine with either. I have talked and read from those who have gone both ways and the consensus I took away is that there is no discernable difference. Lifetime of poly is supposed to be longer but I doubt I will be driving this thing in 20-30 years anyway.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
#15 |
Resurrecting an old thread -
I’m hoping to tackle some panel alignment issues and figured I’d start with the bushings. They don’t look terrible, but would appreciate some perspective from you all. Will swapping out for new make for a better or easier time aligning the doors fenders and hood? 1970 C10 Thanks - |
#16 |
Yep, Best to replace all the body bushings, before you try any alignment. Makes it easier. In the long run.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
#17 |
![]() Join Date: Dec 2013
Don't forget the core support bushings as well .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#18 |
Thanks for the advice!
| Bookmarks |
