Old 03-15-2013, 09:54 AM   #1
63chevy4x4
63chevy4x4's Avatar
1963 hafl ton 4x4 shocks
Dose anyone have a part number for the front and rear shocks for a 63 half ton 4x4? i looked up some threads and found a couple rancho numbers, rs5008 for the front and rs5116 for the rear but the were talking about a 3/4 ton. would those work on my half ton? thanks!
63chevy4x4 is offline   Reply With Quote
Old 03-15-2013, 10:26 AM   #2
j.kirn
Re: 1963 hafl ton 4x4 shocks
they will work, do you have shocks on it now if you do meausure them collapsed and extended then go to your flaps and give them the meaurements and they should find a shock for you
j.kirn is offline   Reply With Quote
Old 03-15-2013, 04:03 PM   #3
'63GENIII
'63GENIII's Avatar
I run the 9000's on mine. If you want I can get pn's when I get home so you could cross reference them?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-15-2013, 05:30 PM   #4
63chevy4x4
63chevy4x4's Avatar
Thanks guys!
Old 03-15-2013, 07:02 PM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
When you want to option a Heavy Duty shock absorber on a C10 you can use a shock from a C20. According to the parts book, the same shock absorber, group 7.345, is used on a K10 or K20 from 63-66 GM part #3197643 for the front and part#22012166 for the rear. The rear part number is a newer number that supersedes the original.
Old 03-15-2013, 08:41 PM   #6
argonaut
argonaut's Avatar
I can help you spec out a Bilstein if you can measure the resting length of the damper.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
