Old 03-18-2013, 09:51 AM   #1
808486CHEVY
808486CHEVY's Avatar
87 1 Ton 454 EFI swap to 84 1/2 ton
Ive searched and read about this swap. I have the whole donor truck, and was going to convert to carberated but Id really like to keep the efi... How bad is the swap to keep the efi? Is it as easy as pulling wiring harness and reinstalling? Also what are the opinions of goin carb over keeping efi.
808486CHEVY is offline   Reply With Quote
Old 03-18-2013, 10:34 AM   #2
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: 87 1 Ton 454 EFI swap to 84 1/2 ton
It's that easy. Keep the efi
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-18-2013, 10:36 AM   #3
jbristo67
jbristo67's Avatar
You'll also need the tank and the fuel pomp
2011 Nissan Armada
Old 03-18-2013, 04:43 PM   #4
808486CHEVY
454 TBI has a smog pump on it. Can i do away with it or will that just cause problems?
Old 03-18-2013, 06:54 PM   #5
Ziegelsteinfaust
Tuning can get of the pump, but if your going to pay the money.
I would a TBI Hypertech bowl, headers, good exhaust, and that way you get the free hp with the tune to take real advantage.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-18-2013, 07:46 PM   #6
thesickc10
If you get a tunable computer it makes it easier for mods. Im doing the same thing but with a 96 suburban vortec 454.
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 03-19-2013, 12:53 AM   #7
rfmaster
rfmaster's Avatar
Yes, you can get rid of AIR pump. ECM only activates vacuum to the AIR pump during cold start to heat up CAT quickly to operating temperature. No tuning is required.
If you change camshaft, exhaust or heads tuning will be required since volumetric efficiency will shift far enough from the factory tune.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
