Old 03-24-2013, 11:26 PM   #1
slepysal
slepysal's Avatar
60-63 vent window glass
Has anyone replaced just the vent glass ? Any tips on how to do it ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-25-2013, 04:29 PM   #2
Blue_Aura
Blue_Aura's Avatar
Re: 60-63 vent window glass
Someone must have, since 1 have two extra sets of vent glass for my truck. One is tinted (looks like a custom or factory job, since the tint is sandwiched in the middle of the glass), and one clear pair.
Don't know how. I'm sure it is in the FAQ or Stickies. I know I saw it here somewhere.
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline   Reply With Quote
Old 03-25-2013, 05:33 PM   #3
WhippinSaw
WhippinSaw's Avatar
Not a 63 but should be close from Alan's classic http://67-72chevytrucks.com/vboard/s...d.php?t=351471 Been keeping this in my favorites for when I get to mine.
WhippinSaw is offline   Reply With Quote
Old 03-25-2013, 06:02 PM   #4
1963c-10
1963c-10's Avatar
I dont know if only the vent can be removed w/o removing the glass as well, but there are two screws at the top of the door over the vent, two on the part of the door facing the cab where the vent is and two under the inner door panel to the left of the large round opening (driver side) and to the right if passenger side. These screws release the vent. I think that you have to take at least the door glass out ( remove from the window sash) to get the vent out. I say this because the door division bar is mounted to the vent.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-25-2013, 06:09 PM   #5
slepysal
slepysal's Avatar
Thanks guys, I dont want to remove the whole vent assembly only the glass. Thanks for the link Whipingpost.
Old 03-25-2013, 06:17 PM   #6
1963c-10
1963c-10's Avatar
I dont know of any way to remove the glass from the vent w/o removing it. Someone else may have a solution though.
Old 03-25-2013, 06:53 PM   #7
hotrodder
YOU CAN TAKE THE SCREWS OUT OF THE GLASS SASH CHANNEL AND LET IT MOVE ON DOWN A LITTLE. THEN AFTER YOU HAVE REMOVED THE SCREWS THAT HOLD THE VENT WINDOW ASSEMBLY, TILT IT BACK AND LIFT IT OUT. THERE IS JUST ENOUGH ROOM FOR IT TO COME OUT. YOU MAY HAVE TO ROTATE IT A LITTLE, BUT IT WILL COME OUT
hotrodder is offline   Reply With Quote
Old 03-26-2013, 10:43 AM   #8
slepysal
slepysal's Avatar
Thanks for the tips. The po had replaced the right vent window with plexigalss. It is now glazed and "spider webbed" so I want to replace it. I 'll keep you guys posted .
Old 03-26-2013, 11:39 AM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
Per the 1960 Chevy Truck Shop Manual, you can just pull the glass out of the frame after softening the seal with gasoline. Back in the old days I always used lighter fluid instead as it was easy to control. Don’t set it on fire just let it soak until the seal gives up its bond. I replaced vent windows several times this way on my 54 Chevy.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-26-2013, 01:27 PM   #10
1963c-10
1963c-10's Avatar
Don't let the EPA hear that Mark. They'll want to recall the original assembly manuals. Hahaha
Old 03-26-2013, 01:56 PM   #11
slepysal
slepysal's Avatar
Thanks Mark very cool !! 1963c-10 so true especialy here in Cali
Old 04-04-2013, 01:08 AM   #12
slepysal
slepysal's Avatar
Thanks again I was able to remove and replace the right hand side. Will do the left one this weekend
Old 04-12-2013, 03:57 PM   #13
slepysal
slepysal's Avatar
both sides are done, now I have to TRY and replace the vent window seals
