03-29-2013, 01:05 AM | #1 |
cragar wheels
i'm looking to put on the cragar 616c wheels 6x5.5 size 18x9 wheels and they say they won't work and i'm trying to figure out why that is. I have changed the front to disc brakes and so i'm not sure if they think i still have drum brakes and that is why they say they won't work. the pickup is a 1967 chevy c-10 swb 6 lug.
03-29-2013, 01:57 AM | #2 |
Re: cragar wheels
Checked the wheel out, but didnt go to their website to get the backspacing or offset. It that wheel is only offered in a high offset with a lot of backspacing, the may be wondering if you will have turning clearance issues. With the wheel size being 18 they wont worry about the rotors or drums.
03-29-2013, 07:19 AM | #3 |
Re: cragar wheels
They won't work because 5 0n 5.5 isn't a GM bolt pattern. You need 5 on 5s
03-29-2013, 10:10 AM | #4 |
Old member
Re: cragar wheels
If your wheels are 6 lugs then you should be able to use them. According to discounted wheel wharehouse anyway.
2001 Chevrolet Pickup K2500 - 6 lug 6 lug 5.5 inch or 139.7 mm Standard Offset there are many more also. http://www.discountedwheelwarehouse...._Reference.cfm The only thing is the center hole may not be big enough on some of the wheels to fit the hub. Normal Chevy truck hubs are 5 on 5. Depending on the conversion kit u used they could be the 5 on 4.75 wheels. But as stated 5.5 isn't a standard 5 lug wheel.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-29-2013 at 10:18 AM. |
03-29-2013, 10:16 AM | #5 |
Re: cragar wheels
OP states 6 x5.5. Chevy pattern.
Could be the hub bore isn't large enough for your still (?) stock rear... which can easily be altered as I did on the Summit Legend wheels. |
03-29-2013, 10:27 AM | #6 |
Re: cragar wheels
the backspacing is 5.790in and the offset is +20.00mm center bore diameter is 3.075in
03-29-2013, 10:30 AM | #7 |
Re: cragar wheels
i have the 6 lug setup on my pickup and i changed the front to disc brakes but stayed with the 6x5.5 lug setup
03-29-2013, 10:54 AM | #8 |
Re: cragar wheels
5.79 will put your wheel inside a fair bit but could work on the front. Guess that depends on wheel width. Bore will not be an issue on front. To the rear, the 5.79BS will rub inside. You'd want a spacer to move the wheel out and then bore wouldn't be an issue either. I have 4.5"BS on 8" wheels with 1 1/2 spacer (net 3 1/2" BS) and it looks perfect.
