Old 04-04-2013, 02:44 PM   #1
vegadesign
vegadesign's Avatar
Question shocks?
im in the process of bagging the front of my truck, im aware i need a shock relocation bracket that im going to make myself
but my question is what shocks do you recommend for the front.
im not looking to spend much money so cheapies work great
if you have a part number that would be great
thank you ahead
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 04-04-2013, 03:34 PM   #2
thekid54
Re: shocks?
When I put a 73-87 front end under my '63 frame I just used the applicable Monroes for the 73-87 year range. Don't have a P/N since I'm at work, but could look it up later. I'm not familiar with the '70 LCAs, but do you really have to relocate the shocks? I used the stock mounting locations on my front end, which was bagged and Z'd 3".
Panel Beaters C.C.
thekid54 is offline   Reply With Quote
Old 04-04-2013, 07:38 PM   #3
vegadesign
vegadesign's Avatar
Re: shocks?
I'm using the stock locations
The relocate will jus move the top loop up 2"
The shortest shock I can find is 9" compressed
It's mainly the compressed height I'm worried about
Old 04-05-2013, 12:05 AM   #4
thekid54
Re: shocks?
I used a Monroe #34817. The spec sheet says it has a compressed height of 9.875" and it worked for me. I was running a 3" Z, bags with a short cup on bottom, 3" drop spindles with 205/75/15 tires, and I laid frame.
Laid out:
About ride height:
Panel Beaters C.C.
Old 04-05-2013, 12:26 AM   #5
broey
Square
broey's Avatar
Re: shocks?
Toxic shocks are good. They have been a go to shock for bagged trucks forever.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-05-2013, 01:29 AM   #6
maxxxy
maxxxy's Avatar
Re: shocks?
I have a set that came with my truck when i first got it (7/9" monoleaf and bags) that are toxic shocks. I think they are specific to a late 90's ford explorer.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 04-05-2013, 12:15 PM   #7
vegadesign
vegadesign's Avatar
Re: shocks?
I guess I forgot to mention my setup huh.
The front:
No Z'd front end
Cupped lower control arm and stock shocks
Stock shocks have a 10 1/2" compressed and 14 3/4" extended
As it sits right now like in my profile pic the shocks have another 2" of play to lower down
The rear:
Monster notch
Stock trailing arms/ 3" blocks
Shocks from 07 fj crusier
I know in the front the shocks are not towards the outside of the lca's so the pivot angle isn't the same as the actual drop so it should be like a 2-1 ratio
But I just want to know what would be the lowest compressed shocks I can get that you guys have used
Sorry to be a pain, I often am lol
Old 04-05-2013, 01:32 PM   #8
Sammy
Re: shocks?
Early Classic's kit with relocator brackets n shocks just over $200
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-05-2013, 02:34 PM   #9
thekid54
Re: shocks?
Try the Monroes, I think they'll work for you. Having the frame Z'd or not doesn't matter because the upper shock mount doesn't move up in relation to the crossmember/LCA, they all move up together when the frame is Z'd.
Panel Beaters C.C.
