Old 04-06-2013, 08:18 PM   #1
bhc41051
bhc41051's Avatar
62 K10 frame sees the light of day
I finally bought tires; I just couldn't resist pushing it outside and washing the dust off. It's getting very hard to find American made 235/75R-15's in a black wall these are Firestone AT's... So so much work to do......
bhc41051 is online now   Reply With Quote
Old 04-06-2013, 08:49 PM   #2
RANDY COX
RANDY COX's Avatar
Re: 62 K10 frame sees the light of day
Lookin good,Lookin good...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-07-2013, 05:54 AM   #3
aerotruk63
aerotruk63's Avatar
It`s all in the details. Looks great so far.
Old 04-07-2013, 12:21 PM   #4
BLK65K10
Looks like your on the road to a nice truck!
BLK65K10 is offline   Reply With Quote
Old 04-07-2013, 12:59 PM   #5
61K10
61K10's Avatar
I wish my frame was done like yours--nice job. did you rebuild your leaf spring bushings? and if so how hard was it taking them apart?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-08-2013, 01:25 AM   #6
Captainfab
60-66 Nut
That looks great
Do you happen to have part numbers for the shocks you used?
Old 04-08-2013, 08:25 AM   #7
bhc41051
bhc41051's Avatar
Yes I replaced pins and bushings friont and rear. I also replaced the shackles on the front. The front end rear spring mount bushings were really tough. I was afraid the rear springs would be hard but they came right apart. The shop manual says to use a slide hammer to remove the pins; but I used a brass drift and drove them inwards. I'm glad I replaced everything it really snugged up the suspension... I also replaced a couple of broken leaf springs..
Old 04-08-2013, 08:35 AM   #8
bhc41051
bhc41051's Avatar
Originally Posted by Captainfab View Post
That looks great
On the front I used Rancho RS5008 and the rear RS5114. I'm a little worried about the length of the rear shocks, as it sits they're almost extended to the max.. I hope after the cab and bed areinstalled Things will work out. I'm not planning on any off roading..
Old 04-08-2013, 10:49 AM   #9
padresag
on the rears on my 64 i used rs5601 but they do mount differently on the inside of the frame and mount off a bolt coming thru the middle of the frame. there is a chart for length and length of travel from the manuf.
ron
padresag is offline   Reply With Quote
Old 04-08-2013, 11:55 AM   #10
1963c-10
1963c-10's Avatar
Off to a great start.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-08-2013, 12:19 PM   #11
gofastnut
gofastnut's Avatar
Looks good! Keep at it!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 04-08-2013, 07:03 PM   #12
j.kirn
gonna be a good looking truck especially the color
j.kirn is offline   Reply With Quote
