Old 04-08-2013, 05:03 PM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
LSx waterpump with Driver Side Connection
*** I found this info over on Pro-Touring.com and thought it would be useful over here. This may make it easier to keep your stock radiator during a swap...
This is the water pump for the 2010+ L99 Camaro (#19207665). It uses the same accessory spacing as the truck motors:
Rich
1972 K5 Blazer CST Click HERE
Old 04-08-2013, 05:06 PM   #2
mcmlxix
mcmlxix's Avatar
Re: LSx waterpump with Driver Side Connection
You will also need the tensioner as well. found the PN on Rockauto... ACDELCO Part # 12628025
Rich
Old 04-08-2013, 05:24 PM   #3
mooseknuckles
mooseknuckles's Avatar
good to know...
mooseknuckles is offline   Reply With Quote
Old 04-08-2013, 06:22 PM   #4
thotfulspot
There is a company called LS Brackets that sells on eBay and their own site that sells relocation brackets to be used with that idler.
http://lsbrackets.com/
thotfulspot is offline   Reply With Quote
Old 04-09-2013, 01:40 AM   #5
BigDan3131
BigDan3131's Avatar
I'm going a different route because of the dual quads I can use this: http://www.summitracing.com/parts/edl-8895/media/images Its kind of pricey but the electric pumps are double that price and more.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 04-26-2014, 01:58 AM   #6
solidaxel
solidaxel's Avatar
That might be the inch I am looking for !!!
What is the difference in pumps lengths?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-26-2014, 02:07 AM   #7
solidaxel
solidaxel's Avatar
Does the 2010 Camaro pump need the dirty dingo spacers?
I see the tensioner is that all that is needed?
Will the tensioner that you list still be needed with a dirty ding upper A/C bracket?
LS 3 4L70E
Old 04-26-2014, 12:23 PM   #8
dayj1
About 1/4" maybe 3/8" at the most (the Camaro pump being the shorter of the two). The angle of the picture makes it look like more than it is.
No, the Gen 5 Camaros have VVT. So, the water pumps are spaced out pretty far to clear the timing cover. The belt spacing is the same as the Gen III/IV truck engines.
Yes. The thermostat and water neck comes with the pump. There is money to be saved by buying an LS1 'vette tensioner. They're about $40 cheaper than the Camaro one and it will bolt right up.
dayj1 is offline   Reply With Quote
Old 04-26-2014, 05:01 PM   #9
solidaxel
solidaxel's Avatar
Thanks, I was hoping for at least a inch, but at this stage 1/4+ will help, I have the dirty dingo A/C mount and you say I will need the Corvette tensioner, (a second one?)
LS 3 4L70E
Old 04-26-2014, 05:24 PM   #10
dayj1
I have the L99 water pump on a 4.8 that I'm building right now. I measured it and a spare truck pump that I have and verified for sure that there is 1/4" difference in "height". The shaft of the L99 pump protrudes through the middle of the pulley about 1/8" so you could grind that off to get the last possible bit of clearance. But, keep in mind that the water outlet on the L99 pump points straight forward and is sticks out about the same distance as the pump shaft. The radiator hose is going to be furthest thing from the block. In other words, if whatever you're trying to create clearance for is also in the way of the water pump outlet, the L99 may still give you some fitment problems with the hose outlet.
My comment about the tensioner really wasn't in regards to the DD A/C mount. I just meant that the L99 pump doesn't come with a tensioner and the LS1 corvette tensioner will fit it (and the 'vette tensioner is about $40 cheaper). I have no experience with the DD mount.
Old 04-26-2014, 11:24 PM   #11
solidaxel
solidaxel's Avatar
Thanks, I wonder how much I can cut off the snout and still hold it to the shaft, it is pressed on, right?
The 5.3 is going in a 46 Chevy pick up
LS 3 4L70E
Old 06-03-2014, 01:56 PM   #12
smartass12
smartass12's Avatar
I know this is kinda old thread but does this water pump outlet clear the stock 5.3 alternator bracket looks like it might hit?
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 06-03-2014, 11:20 PM   #13
dayj1
The water outlet on the L99 pump does hit the alternator bracket on the part that holds the idler pulley. Most folks are using the L99 pump on a truck engine are switching to a car intake. So, they are relocating the idler anyway because it interferes with the throttle body.
Here's a picture that I stole off ls1tech that shows what I'm talking about. Note the relocated idler:
