Old 04-08-2013, 07:11 PM   #1
wahl4m
late dually wheels to 83 1 tonner ?
i have a 83 chevy car hauler -1 ton -c-30-i would like to put some later 90s -wheels w/fancy rings and caps -whats needed ?i was told to just buy some adapter nuts ? where ? OR will the 2012 year -17" wheels fit ? also what nuts and so forth ?anybody done either ? thanks mike
wahl4m is offline   Reply With Quote
Old 04-08-2013, 07:13 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: late dually wheels to 83 1 tonner ?
2011-up 3/4-ton and 1-tons have a different bolt pattern.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 04-08-2013, 07:16 PM   #3
wahl4m
thanks for the info-i looked at a 2012 on dealers lot -they did look like a wierd bolt pattern !guess im back to the 90 abd newer styles !
Old 04-08-2013, 07:26 PM   #4
lolife99
lolife99's Avatar
2010 on back, should be the same bolt pattern.
Keith
Old 04-08-2013, 09:19 PM   #5
83GMCK2500
Regarding lug nuts, look for 9/16" conversion lug nuts. They will look like the newer lug nuts with the external threads but have a 9/16" center instead of M14. The external threads are used by the center cap retainers.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-09-2013, 10:55 AM   #6
Desert1957
Desert1957's Avatar
Be aware of some other wheel info, the center hub bore diameter is larger on new style wheels causing wheels to run off center. You can fix it by using a "Hub Ring" or just checking the wheels before you purchase them.
Here is some helpful info...
76-2000 Hub Bore is 4.56 / wheels are 8 X 6.0
01-2007 Hub Bore is 4.60 / wheels are 8 X 6.5
Desert
Desert1957 is offline   Reply With Quote
Old 04-09-2013, 11:21 AM   #7
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
True, but having a machine shop drill out the correct pattern is not a big deal at all, but keep in mind the hub bore diameter.
76-2000 Hub Bore is 4.56 / wheels are 8 X 6.5
Desert
This, in 01 they went to the larger 4.60" hub bore. This translates into just over 1/32" diameter difference, or about 1mm. Meaning the wheel is free to move about 1/64" or 1/2mm in any direction before torquing down. You will not find a hub ring that small, and that small of a difference will not get the wheel far enough off center to cause much of a vibration. Just put the wheel on, and torque it down and it will be fine.
It WILL be an issue if he used 8x6.5" Ford wheels with a 4.88" bore, older Dodge with a 4.75" bore, or newer Dodge with a 4.78" bore, although with those sizes, a hub ring would be feasible to machine.
If you just want the "fancy rings and caps" just put them on your wheels. As 83GMC mentioned; just get the correct conversion dual threaded lug nuts, IIRC McGard produces them, in 9/16 with the external threads. Then just thread on the newer caps, and pop on the rings to your existing wheels.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 04-09-2013, 06:17 PM   #8
wahl4m
THANKS EVERYBODY !! i knew somebody would have the answer !! now to find some wheels -seems like -there hard to find ?? thanks mike
