Old 04-11-2013, 05:20 PM   #1
BadaSs_Cal
BadaSs_Cal's Avatar
Noob Question about radiators
So I have my heart set on replacing my old leaky radiator with an inexpensive Aluminum off ebay..
I know.. I know you get what you pay for..
my question is more of a technical one.. If the fittings are the same and the radiator fits.. then I should be good to go right?
Or is there a specific, spec, to look for?
This is going into a 66 GMC with a 351e V6..
Thanks in advance for the help.
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline   Reply With Quote
Old 04-11-2013, 05:26 PM   #2
ChuckW
ChuckW's Avatar
Re: Noob Question about radiators
If it fits and keeps the MoMo cool then it's good to go!
ChuckW is offline   Reply With Quote
Old 04-11-2013, 05:29 PM   #3
BadaSs_Cal
BadaSs_Cal's Avatar
Thanks Chuck!
Next a 50-53!
MY BUILD THREAD
Old 04-11-2013, 09:05 PM   #4
neto
Are you not able to have yours recored? or fixed for less or about the same as a new one?
neto is offline   Reply With Quote
Old 04-12-2013, 02:05 AM   #5
Trsmotrhed
Trsmotrhed's Avatar
I got the champion one off eBay and very happy. Got the electric fan also because went with LT1. Had to trim the top rubber and fit great. Know several guys running them and work great.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 04-12-2013, 09:07 PM   #6
Irishbleueyes
Why are you getting an aluminum one? Oreilly's has the factory new rad for $210 and that comes with lifetime warranty, hard to beat that deal....
Irishbleueyes is offline   Reply With Quote
Old 04-12-2013, 09:43 PM   #7
cortcomp
cortcomp's Avatar
i put the eagle/champion $170 dual 1" core one in my 71 pontiac 462 with upgrades, almost 450HP, 500 ft lbs, factory clutch 7 blade 19" fan, factory shroud, no electric fans, 160 thermostat, runs at 165 degrees, even in the 110 degree heat/3 hour drive and idling in a goodguys car show for 30 mins to parking spot. I scuffed the tanks that stick out of the shroud and painted them black to blend in more with the factory looking engine bay.
Hard to beat that deal more than a factory rad for $200. Nice and new and clean!
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 04-12-2013, 11:02 PM   #8
Trsmotrhed
Trsmotrhed's Avatar
I went through 3 of those radiators before I gave up on one that didn't leak or smashed from shipping. Plus it didn't cool as good as the aluminum one I have now.
63 SWB C10
