Old 04-12-2013, 08:30 AM   #1
Daddy Brim
Daddy Brim's Avatar
Visor Lube ?
My sun visors are hard to pull down. I used a silicone spray but it did not help much. Was wondering what can be used that will not damage my visors ?
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 04-12-2013, 08:39 AM   #2
cdowns
cdowns's Avatar
Re: Visor Lube ?
use WD40 to clean out the old crap and carefully work them repetedly up and down to break free of the surface rust that causes the stiffness in it then followup with white lithium spray grease
Old 04-12-2013, 08:46 AM   #3
luvbowties
luvbowties's Avatar
Smile Re: Visor Lube ?
Might help to slide visor off its "stem" & lube the stem itself.
sam
luvbowties is offline   Reply With Quote
Old 04-12-2013, 09:05 AM   #4
Daddy Brim
Daddy Brim's Avatar
Re: Visor Lube ?
sam
To get off of the stem do you just pull and twist. Will WD40 or grease harm the visor ?
Old 04-12-2013, 09:57 AM   #5
luvbowties
luvbowties's Avatar
Question Re: Visor Lube ?
At least, that's opposite from the way they are installed. Do yours have a screw that adjusts tension on the stem?
sam
Old 04-13-2013, 07:59 AM   #6
Daddy Brim
Daddy Brim's Avatar
Re: Visor Lube ?
sam
No screws, This is a 67 if that makes any difference.
