Old 04-12-2013, 03:17 PM   #1
b1kem1ke
Sanderson CC11 headers
Has anyone got these to work? Sanderson claims they should work, but every vehicle is a little bit different. I have about a 1/4" clearance to the engine mount bracket on the driver's side, the passenger side touches on my 'test fit', will get worse after bolts are snugged (maybe 1/4" interference).
It's the 'bulge' of the bracket that's in the way. How much clearance is ideal/minimal? Does anyone know of some brand with more header clearance? Or engine mounts that sit the whole engine maybe 1/2" higher? If so, is it an 'easy swap', i.e. lift the engine slightly to replace without a removal? I'm a machinist, thinking of making my own, but don't want a time consuming project if there's an easy fix I'm overlooking.
Here's the side that is o.k., but you can see where the tube is close. That's where the problem is at on the other side.
b1kem1ke is offline   Reply With Quote
Old 04-12-2013, 03:38 PM   #2
nicolas72gmc
nicolas72gmc's Avatar
Re: Sanderson CC11 headers
The Sandersons that Early Classic Enterprises sells clears just fine. I think they are the CC10's. You can find them on their website. I'm running them with no problems.
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 04-12-2013, 04:59 PM   #3
b1kem1ke
Thanks. Just looked at their site. They have their own numbering system (no CC#), but they look like the ones I have. Might have to call Sanderson...
Old 04-12-2013, 05:31 PM   #4
nicolas72gmc
When I called to order these, (like a year ago), I recall Mark, from ECE, telling me they were the #10 model. Hope this helps.
Nick
Old 04-12-2013, 11:46 PM   #5
jgmc
I bought the Sanderson headers a few years back from Early Classic and they didn't work for me either. I ended up with Stan's Headers made right in the beautiful state of Washington.
jgmc is offline   Reply With Quote
Old 04-12-2013, 11:53 PM   #6
Z10
Z10's Avatar
Soon to find out if the CC11 fit my 72. These were recommended by another forum member who is using them.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 04-13-2013, 12:24 PM   #7
Gmcfolife
Gmcfolife's Avatar
I have the ECE headers which are the cc10's I have at least 3/4" clearance on each side.
Gmcfolife is offline   Reply With Quote
Old 04-13-2013, 12:25 PM   #8
Gmcfolife
Gmcfolife's Avatar
Old 04-13-2013, 06:28 PM   #9
rogergodding
rogergodding's Avatar
I have them with no problems, supposed to be cc-10
rogergodding is offline   Reply With Quote
Old 04-13-2013, 08:27 PM   #10
elf w/capital T
Wow, those are slick!!!!
elf w/capital T is offline   Reply With Quote
Old 04-13-2013, 08:52 PM   #11
gonnuts
gonnuts's Avatar
Ditto.
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4
gonnuts is offline   Reply With Quote
Old 04-13-2013, 09:13 PM   #12
Z10
Z10's Avatar
If I'm not mistaken the CC11 are for "D" port heads. That may be the only difference between them and the CC10?
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 04-13-2013, 09:35 PM   #13
nicolas72gmc
And angled plugs.
Nick
Old 04-13-2013, 09:44 PM   #14
nicolas72gmc
Nick
Old 04-13-2013, 09:46 PM   #15
nicolas72gmc
Mine clear no problems
Nick
