Old 04-13-2013, 06:07 PM   #1
da_bears_da1
Shifter advice
I am thinking about buying a Lokar shifter to put in my 65 SWB Step Side. I have a TH400 in it. I like the looks of the Lokar shifters, more old school. Question is what height to get. My bench seat is getting reupholstered so not sure of the height of the shifter. I am thinking a 23" would be best.
Would also appreciate any advice on the shifter, is Lokar a good choice? I like that it mounts to the transmission.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
Old 04-13-2013, 06:15 PM   #2
Indian113
Indian113's Avatar
Re: Shifter advice
I had a 23 inch Gennie Shifter in my 64 and hated it. It looked like a 4 speed shifter but it banged against my knee when I was driving it. My shifter was a tranny mount I think the Lokar cable shifter may be better.
Indian113 is offline   Reply With Quote
Old 04-13-2013, 08:19 PM   #3
gimmy 64
Re: Shifter advice
i have the lokar 23 inch shifter and i really like it. nostalgia or how ever you spell it. it's the one with the curve in it. it does not come anywhere near my knee. very nice product.
gimmy 64 is offline   Reply With Quote
Old 04-13-2013, 09:38 PM   #4
Lugnutz65
Lugnutz65's Avatar
Re: Shifter advice
I just came back from the Charlotte Auto Fair.
Here's the Lokar Shifter Display.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-14-2013, 07:01 AM   #5
da_bears_da1
Re: Shifter advice
Thanks! Did you get the transmission mount or cable?
Thanks Lugnutz! I did not realize there were so many styles.
Jeff
Simplify Life!
Old 04-14-2013, 12:29 PM   #6
Lugnutz65
Lugnutz65's Avatar
Re: Shifter advice
I have not chosen a shifter yet. I do tend to research stuff way in advance. Too far actually! LOL!
I have a T5 5 speed tranny for my 65 C10. The stock shifter handle from a S10 might be OK for starters, but I'm sure I'll eventually want something that looks cooler.
Hurst has some options too. I don't have pics of those.
Jay
Old 04-14-2013, 07:28 PM   #7
gimmy 64
Re: Shifter advice
i have the trans mount. very nice product. i started with it on a 350 and changed it to a 2004r. called lokar about the change and for $80 they sent me all of the parts to use it on the 2004r. pretty simple install also. very good instructions.
Old 04-14-2013, 07:34 PM   #8
1964Chevy
1964Chevy's Avatar
Re: Shifter advice
I bought a TH 400 with a Lokar on it, 16". It was my opinion on it that it was a light weight product. I want to just get in slam it back and drive. I put a B&M Quicksilver on a rebuilt 700r and I like that I can slam it in drive and drive. My issue with the Lokar, and I know many folks who use them, is that it just felt like I could break it off. That's my two cents.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline   Reply With Quote
Old 04-15-2013, 01:30 PM   #9
steveb64
steveb64's Avatar
Re: Shifter advice
I just put the 23" Lokar in my '64 with the TH400. I had to hog out the passenger side banana bracket a bit to get a little more adjustment in the setup for the neutral safety switch. From what I 've seen, this is a common issue with this shifter. Wasn't a big deal and it works fine now.
I also angled the shifter toward the driver a bit instead of straight down the center. It's an adjustment you can make to suit your preference.
I'm also using the Lokar kickdown switch that mounts on the transmission. I didn't like the way the bracket for this unit puts the cable up against the shifter linkage so i fabbed one up that kicks the unit out at a slight angle to keep the kickdown cable away from the linkage.
Other than that, that's my experience with Lokar so far.
steveb64 is offline   Reply With Quote
Old 04-16-2013, 09:20 AM   #10
da_bears_da1
Re: Shifter advice
Thanks for the response. I too liked the idea that the shifter could be altered to fit on a new trans in the future.
Thanks for the feedback.
Thanks! How much did you have to hog out on the passenger side? Do you have any pictures?
This forum is great!
Jeff
Simplify Life!
Old 04-16-2013, 12:16 PM   #11
steveb64
steveb64's Avatar
Re: Shifter advice
I probably extended the adjustment slot 1/16-1/8 inch, not much, but just enough to get the neutral safety switch to open when in Drive.
Old 04-17-2013, 10:37 AM   #12
63burban
Chevy addict
Re: Shifter advice
My 63 has a 700r4 with a Genie shifter, it had a 12" arm, it came out of a 33 Ford street rod. I cut the short arm just above the shifter and welded on an old truck 4 speed lever, looks totally cool, works great. I can't see paying the prices on these new shifters, I re-purpose, that's what swap meets are for, cheap stuff. Makes me B<)
63burban is offline   Reply With Quote
Old 04-17-2013, 01:25 PM   #13
da_bears_da1
Re: Shifter advice
Good idea. Thanks!
Jeff
Simplify Life!
Old 04-28-2013, 08:03 PM   #14
TxRat
TxRat's Avatar
Re: Shifter advice
I just installed a Gennie shifter today. Went in with out any problems. Mounted to a 700r4
TxRat is offline   Reply With Quote
Old 04-28-2013, 09:00 PM   #15
da_bears_da1
Re: Shifter advice
Very nice! Will check out the Gennie. What length is your shifter?
Jeff
Simplify Life!
Old 04-28-2013, 09:17 PM   #16
TxRat
TxRat's Avatar
Re: Shifter advice
Its the Swan shifter arm. They only offer one swan arm. I can measure it if you'd like
Old dogs street rod parts Part number is: 1018L $80.95 Swan Stick
You can get it and the complete shifter assembly from http://www.olddogstreetrods.com/
Good people...
Old 04-28-2013, 09:38 PM   #17
da_bears_da1
Re: Shifter advice
Good people...
Thanks!
Jeff
Simplify Life!
Old 04-29-2013, 07:52 AM   #18
Indian113
Indian113's Avatar
Re: Shifter advice
Gennie Shifter's are No Longer in Bussiness
Old 04-29-2013, 08:39 AM   #19
tincan1966
tincan1966's Avatar
Re: Shifter advice
I've used Gennie, Lokar, B & M, Hurst, almost all of them over the years. Recently I even tried out American Shifter- which is a cheaper version of Lokar.
Like a couple of the others said, if you want to drive your truck and bang gears, then a B & M or Hurst or competion shifter is best. If you want to just put it in gear and look cool, then Lokar is a good choice. For everyday driving, I personally don't like the trigger lock outs on the competition shifters, but that's just me. Mow in the race car- i love my Quarter Stick!
Again, just my opinion, it is your truck and you're the one driving it.
tincan1966 is offline   Reply With Quote
Old 04-29-2013, 09:19 AM   #20
UK62LW
UK62LW's Avatar
Re: Shifter advice
Radical 32" for me
Barney, in the UK
1962 Chevy C20
1974 Ford Econoline
1987 Peugeot 205 GTi
1991 Peugeot 205 GTi
UK62LW is offline   Reply With Quote
Old 04-29-2013, 09:42 AM   #21
jsdoyle
jsdoyle's Avatar
Re: Shifter advice
I really like my Lokar. Put the 8-ball knob on there about month ago. Not in the way at all, even with the better half in the middle seat.
I need to get under the truck though and hook up the back-up light ground! On my to-do list!
65 Chevy C10 Fleetside
jsdoyle is offline   Reply With Quote
Old 04-29-2013, 07:19 PM   #22
TxRat
TxRat's Avatar
Re: Shifter advice
Gennie is alive and well my friend. They sold off some of their other ventures and are open again.
Old 04-29-2013, 08:23 PM   #23
Indian113
Indian113's Avatar
Re: Shifter advice
That's good, we need variety
