![]() Join Date: Jul 2012
Bagged, Bodied, & Blown 68 C10
Here is my newest project, a 68 C-10 Fleetside short bed. I bought it from a buddy at work back in July 2012. The truck is getting a complete overhaul and figured I’d start posting some progress. If you have instagram follow me a “adam_aftermathcalifas” I will be updating with pictures more regularly there if interested.
Before ![]() ![]() ![]() ![]() ![]() ![]() ![]() So far in the works suspension -Custom bodydropped frame -Porterbuilt Front dropmember/with rack and pinion -Michigan Metal Works Jeebus Joint A Arms -Accuair E-Level w/ Accuair VU4 valving -05 Yukon rearend with disc brakes (shortening, gearing, and posi to come) -CPP 13” dual piston brake kit with 2” drop spindles (what to upgrade to 4-6 piston kit) Drivetrain -05 Yukon 5.3l w/4l60e Upgrades include: Polished Magnacharger Radix Supercharger cam is a Texas speed, 224/228, .581/.588 114LSA springs are PAC single beehive .600 lift pushrods are hardened Texas speed 7.400 new Gasket and Fastener kit GM MLS 3 layer head gaskets ARP head bolts GM LS2 upper/lower timing gear and chain Ported GM LS6 oil pump F-Body oil pan Wheels 22x8.5 & 24x15 Raceline Burst wheels with Pirelli P-Zero Nero Tires 265/30/22s & 405/25/24s Much more to come, I will keep you updated |
| Bookmarks |
