Old 04-23-2013, 09:31 AM   #1
86c20
86c20's Avatar
85 to 88 cab
ok so i got a 88 cab to replace the one on my wrecker. what i would like to know is what is needed to be changed? the 88 is wired for tbi and i have a carb so i know i have to change some of that around but how much? can i leve the comp or do i need to change the wire harness?
thanks guys. mike
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 04-23-2013, 10:22 PM   #2
86c20
86c20's Avatar
Re: 85 to 88 cab
anyone???
Old 04-23-2013, 10:46 PM   #3
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: 85 to 88 cab
85 and 88 are two different body styles.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 04-23-2013, 11:30 PM   #4
mtnsackett
mtnsackett's Avatar
Re: 85 to 88 cab
that would be correct if it is a C/K Model but from 88 to 91 there was also the R/V models so he could have one of them.
"Not all those who wander are lost." A.R.R. Tolkien... Some of us are exploring to see what is out there in this world!
mtnsackett is offline   Reply With Quote
Old 04-24-2013, 01:11 AM   #5
86c20
86c20's Avatar
Re: 85 to 88 cab
its one ton to one ton. not the new body. forgot all about that lol. so yea it would be a r/v cab.
Old 04-24-2013, 07:43 AM   #6
GM72K10
Next!
GM72K10's Avatar
Re: 85 to 88 cab
Use the old wiring harness, less problems that way
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 04-24-2013, 09:30 AM   #7
86c20
86c20's Avatar
Re: 85 to 88 cab
can i just use my old engine harness? cause my cab harness is shot to hell. also can i just take the fuse block apart to seperat the frame harness or do i have to cut and splice all the wires?
Old 04-24-2013, 09:42 AM   #8
GM72K10
Next!
GM72K10's Avatar
Re: 85 to 88 cab
If you're taking the fuse block apart best to get a factory wiring schematic, the 2 fuse blocks are not exactly the same
86 K30 CUCV M1028A1
