Know of a good de-greaser?
Know of a real good de-greaser? Ive tried all the auto store degreasers with no luck. Im talking crud caked on for years. Wire brush gets gummed up etc...
Simple green citrus etc.. dont work. Looking for industrial type product. thanks. Glenn
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
Re: Know of a good de-greaser?
scraper for the crud- power wash
ron |
good ole gasoline
1962 C-10
Castrol Super Clean.....
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
If foamy engine degreaser doesn't work good old diesel works. Same stuff or kerosene. Dawn dishsoap mixed with Tide powder for abrasive alternative. Soaking is a must. Pressure washing is always good.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Mix a bucket of Dawn that is fairly concentrated (4 X's the amount). I also include a touch of Tide laundry detergent.
Brush it on the greased up parts very liberally...make sure it penetrates (that's where the laundry detergent helps). Let soak, then hit with a warm water pressure wash. Retreat if necessary and hit lightly with SOS pads and/or steel bristled brush. T
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
Hey 64TanTruck, I just fell into the stuff jchav mentioned. It's not called Castrol Super Clean anymore though, it's just called Super Clean. You can get it for 50 bucks in a 5 gallon bucket or about 4 bucks for a little squirt bottle at Autozone.
You still have to scrape the heavy stuff, nothing will change that but Gasoline that I know of (dangerous). But it'll clean the stuff that won't scrape.
Step by steps: Remove primer to reveal original paint Rebuild a carburetor See My Build - Cecilia! ![]() Some people are like slinkys. Not worth much but funny as heck when pushed down stairs. |
I'm just glad to be here!
if you are not worried about the paint underneath, try EasyOff oven cleaner in the yellow can. Make sure you are out side... I did a frame with it and it does wonders. I hit the thick areas with a putty knife to knock off the big chunks first.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
![]() Join Date: Jan 2011
Another Super Clean fan here...
Por-15 Marine Clean. Holy **** it works better than anything I have ever seen. Wear gloves or it will dry your hands out for a week.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Scrape the major stuff off first, then cheap store brand oven cleaner if it's going to be repainted or wax and grease remover (made for pre-paint prep). The wax and grease remover penetrates and dissolves grease better than anything I've ever used and won't gum up brushes if you use enough. Thins grease to a water-like consistency! It's around 12-15 a gallon for the cheaper stuff, great for cleaning greasy old parts. I like to soak greasy engine/drivetrain hardware in it; it works so good that there's usually no scrubbing required- just slosh it around in a can of bolts.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Who Me?
Oven Cleaner, like Easy Off!!
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#13 |
Scrape off the heavy stuff, apply Laquer Thinner, collect waste and dispose properly.
http://s1299.photobucket.com/user/jb...23904108567829 |
#14 |
oven cleaner is sodium hydroxide(lye) wear gloves, glasses and neutralize after you are done to stop any action (esp the stuff that gets hidden) so that it doesn't cause any reaction with whatever finish you may apply. vinegar will neutralize it and then hose it off with water
ron |
#15 |
![]() Join Date: Oct 2006
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#16 |
dollar store Oven Cleaner...........i used about 4-5 cans....works Great.....
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#17 |
![]() Join Date: May 2007
I used to use this stuff called Red Hot from a local detail shop Knipps. Seems like they changed the name, never used this stuff. It made even the cruddiest old truck engine look brand spanky new
http://www.knipps.com/shop/kps105-er...reasercleaner/ here is the stuff still branded Red Hot, man that stuff worked crazy. I like how they tell you it can be diluted with a great deal of water, thats what I remember is how concentrated it was. http://www.texasrefinerycoatings.com...c_red_hot.html
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#18 |
One more for cheap oven cleaner...
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#19 |
meowMEOWmeowMEOW
Purple Power, which is a floor de-greaser, works really well on misc items if you soak them in a little of it with water.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#20 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Oven Cleaner works killer. Spray it on and keep it wet for 10 minutes or so by reapplying as needed. It cuts all the way through the thick stuff.
![]() Posted via Mobile Device |
#21 |
Used oven cleaner tonight worked great. Rinsed real good, for the night. Will hit it again tomorrow night for the hard to get areas.
Thanks, Glen
#22 |
I'd use any pre cleaner except gas & follow with a Steam / Hot water pressure bath.
#23 |
I bought a 5 gallon bucket of carb cleaner from carquest and not only does it degrease but it strips paint also, its an awesome cleaner.
#24 |
oven cleaner
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
#25 |
I will suggest oven cleaner also. Be warned, be very careful and wear eye protection when using oven cleaner. I was using a brush to scrub off grime with oven cleaner and it flung a bunch in my eyes once, was not fun trying to get to water to rinse it out.
| Bookmarks |
