Old 05-01-2013, 12:04 AM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
break problem
i just installed new break shoes springs ect. in the rear drums.now i cant install the drums,shoes are too pushed out,i loosened the adjust.cylinder all the way,and still having the problem.is there anything im missing?any tips?
1966FLEETSIDE is offline   Reply With Quote
Old 05-01-2013, 12:27 AM   #2
luvbowties
luvbowties's Avatar
Question Re: break problem
Maybe open bleeder valves and compress upper ends of shoes until wheel cylinders depress fully & allow ends of shoes to move completely in?
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 05-01-2013, 01:01 AM   #3
1966FLEETSIDE
Re: break problem
thx sam i will try that,will i have to bleed my lines when im done?or just refill my master cyl.
Old 05-01-2013, 01:43 AM   #4
65'RustBucket
Re: break problem
You will for sure have to bleed your lines after. When you let out fluid it is replaced with air. No fluid, no hydrollic pressure allowing you to move the cylinder without resistance. Presto! Making installing new shoes a breeze! I almost always bleed the system when I repair shoes anyways for both easy install and good servicing!
65'RustBucket is offline   Reply With Quote
Old 05-01-2013, 10:00 AM   #5
1966FLEETSIDE
Re: break problem
thx rustbucket,is it a one man job or does it take two peeps.is there an easy tool for bleeding brakes?
Old 05-01-2013, 12:04 PM   #6
61K10
61K10's Avatar
Re: break problem
make sure the shoes are pushed together at the wheel cyl. (cyl pins are pushed into the cyl all the way) you can do this with your hands.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-01-2013, 01:00 PM   #7
65'RustBucket
Re: break problem
Ideally 2 people is best, but there are 1 man hand pump bleeder tools.
Old 05-02-2013, 12:37 AM   #8
1966FLEETSIDE
Re: break problem
ok thx
