Old 05-01-2013, 12:51 PM   #1
sodly
sodly's Avatar
Ground strap location
Can anyone tell me where this ground strap belongs? One end is screwed into the firewall but the other end is loose. This is a 66 C20 with a 327. Thanks!
sodly is offline   Reply With Quote
Old 05-01-2013, 01:21 PM   #2
Cobblemizer
Re: Ground strap location
Should be bolted to the back of the cyl. head
Cobblemizer is offline   Reply With Quote
Old 05-01-2013, 01:56 PM   #3
Vernski
Check the diameter of the hole in the ground strap that will give a clue. Are you looking for the factory location for resto purposes? And I don't know for sure, you might check in the factory assembly manual. I'd just match it up to the closest bolt that fits in the hole in the strap. Someone changed motors and forgot to hook it up I'm guessing, good luck...Vernski
Vernski is offline   Reply With Quote
Old 05-01-2013, 02:22 PM   #4
sodly
sodly's Avatar
I was thinking it goes to the engine as well. But where? Does it just go to a valve cover bolt?
This is an original truck, btw.
Old 05-01-2013, 04:24 PM   #5
Rich 5150 69
Rich 5150 69's Avatar
Valve cover is acceptable, some chevy models, used the valve cover bolt for the ground, my original is on the inner front fender right side to frame...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-01-2013, 04:38 PM   #6
gofastnut
gofastnut's Avatar
Originally Posted by vernski View Post
check the diameter of the hole in the ground strap that will give a clue. Are you looking for the factory location for resto purposes? And i don't know for sure, you might check in the factory assembly manual. I'd just match it up to the closest bolt that fits in the hole in the strap. Someone changed motors and forgot to hook it up i'm guessing, good luck...vernski
x2
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 05-01-2013, 04:48 PM   #7
sigshooter
sigshooter's Avatar
Back lower valve cover bolt is the correct location
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 05-01-2013, 05:15 PM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Check this link for all locations.
http://67-72chevytrucks.com/vboard/s...t=ground+strap
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
