Old 05-04-2013, 04:50 PM   #1
dirt_migirt
Converting brakes
I was wondering if anyone could me the cheapest way and easiest to convert from manual brakes to power brakes on my 1977 c10
dirt_migirt is offline   Reply With Quote
Old 05-05-2013, 12:56 AM   #2
dirt_migirt
Re: Converting brakes
does anybody know if I have to change the pedals when converting from manual brakes to power brakes and does anyone have any advice/parts list needed to make the swap
Old 05-05-2013, 01:19 AM   #3
ol'blazer
ol'blazer's Avatar
you dont even have a brake booster?
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 05-05-2013, 08:34 AM   #4
dirt_migirt
No it was past 3 on a Saturday here in my town and all shops part stores and salvage yards are closed
Old 05-05-2013, 10:13 AM   #5
Shyguy
Junior Member
Shyguy's Avatar
You won't have to change the brake pedal. If you get a booster from the junk yard make sure you get the booster, the brackets and the rod. Also the the hose with the, I call it valve in it.
If the booster is bad it can be used for a core.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-09-2013, 09:43 AM   #6
esbstuff
I will have to disagree. The brake pedal is differant. The rod pin that is made on the pedal is a differant size.
esbstuff is offline   Reply With Quote
Old 05-10-2013, 11:21 AM   #7
wraprail
wraprail's Avatar
I converted from power to manual on my 85. I think yours would be the same.
The brake pedal is the same. The power booster push rod connects to a large pin that is welded on the pedal.
The manual pushrod connects with a special bolt and goes in a hole in the pedal. The manual pushrod is located above where the power booster connects. This gives the manual brakes the lower pedal ratio that they require
wraprail is offline   Reply With Quote
Old 05-10-2013, 12:09 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
Smile Re: Converting brakes
You sure could be right. When we made the brakes on my '71 power we used the same brake pedal. We installed a booster with bracket and push rod we got at a swap meet. It works, but the brakes are a little touchy.
We converted manual brakes on a '69 and '70 the same way with drum brakes to power brakes and they both work ok.
Of course when my son and I get together we tend to do a lot of stuff people say can not be done since we don't know any better.
I am not as familar with the '73 and newer trucks, but I am learning more as my journey continues working on the '75 C-30 dually I bought.
