Old 05-04-2013, 11:14 PM   #1
Skunksmash
Skunksmash's Avatar
Which adhesive for sticking stuff to the body?
I just had my truck painted, but to save a little cash I'm doing some of the things myself. It needs a new silverado badge, and I don't really want to take the fender off. I want to glue it on there. Also, I didn't buy those off-kilter looking trim pieces that that wrap around the bed under the tail lights. I just used the same trim that goes on the sides so that it would all look uniform. So of course I will need some stronger adhesive so that those don't come off.
Which adhesive should I use for permanently gluing stuff directly to the paint?
Skunksmash is offline   Reply With Quote
Old 05-04-2013, 11:21 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Which adhesive for sticking stuff to the body?
Use 3M double sided tape. You can get it in rolls so you can trim off what you need. Cleans up somewhat easily if you have to remove it.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 05-04-2013, 11:25 PM   #3
andrewmp6
Yeah the 3m tape is what most vent visors are held on with.
andrewmp6 is offline   Reply With Quote
Old 05-04-2013, 11:47 PM   #4
bilfman
bilfman's Avatar
X3 on the 3m tape. 3m products are top shelf!
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 05-04-2013, 11:50 PM   #5
Skunksmash
Skunksmash's Avatar
Ok I will get the 3M tape. There are many 3M tapes, but I take it this would be the only one for use on the exterior? Also since it is a tape, is it going to make the fender badge look like its sticking out slightly further than the other side is?
I have to admit I'm a little leery of using a tape to make sure these things don't eventually just fall off the truck when I'm driving down the road.
Old 05-05-2013, 12:04 AM   #6
bilfman
bilfman's Avatar
I've heard it referred to as body molding tape. Don't worry about it sticking. If both surfaces are clean you need a pry bar to get it off.
Old 05-05-2013, 12:07 AM   #7
Damon23
Damon23's Avatar
I bought a huge roll off eBay years ago. It is half inch wide and thin. Works great. Didn't make the emblems I was putting on my old bronco stick out too much.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 05-05-2013, 12:08 AM   #8
Skunksmash
Skunksmash's Avatar
Here it is:
http://www.3m.com/product/informatio...ding-Tape.html
Old 05-07-2013, 06:56 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
spend a bit extra for good stuff
I found other uses too
don't make a pocket sealed by it,keeping ,moisture and dirt trapped
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-07-2013, 06:46 PM   #10
BONUSCAB
Any pics?
BONUSCAB is offline   Reply With Quote
Old 05-07-2013, 09:12 PM   #11
Damon23
Damon23's Avatar
If you don't need it like yesterday I'll take some off this roll I have and send it to you if you'd like to try it out. It is 3M and is about the thickness of the stuff skunksmash posted but is not as wide. Just PM me your address and I should be able to get it out in the next few days.
