Old 05-07-2013, 12:23 PM   #1
ChevyJr
Junior Member
ChevyJr's Avatar
Exclamation 700r4 Swap
I know there are a million threads addressingthis, but I am really lost in all the comments that do not seem to match up. I pulled a 700r4 from a 93 camaro Z28 with an LT1 V8 engine. I have seen the many lockup options but am still a litle lost. I am basically needing guidance as to how to go about my particalar project. Please excuse my ignorance but this is my first automatic trans swap. Attached is a terrible picture of the tranny, but I will post better pictures later tonight. In the process of cleaning it for painting.
*Is there a difference between a lockup kit and a lockup torque converter. I believe the tranny I have is equipped with a lockup torque converter according to different forums and vehicle information.
*The tranny has a 5-pin connector instead of a 4-pin connector. I understand that in the 1993 that is the correct connector, yet I have only seen ppl upgrade to this tranny/connector not "downgrade" to a 4-pin connector. If i do in fact need a lockup kit, is it possible to change the 5-pin to a 4-pin?
*Is a detent cable the same as a TV cable? I dont know that I remember that when removing this tranny. I have a Holley Street Avenger and the Holley video show them hooking up a detent cable and a TV cable so I asumme the answer to my question is no, but I know those videos can be very gereric.
Any other information would be extremely helpful. Thanks.
ChevyJr is offline   Reply With Quote
Old 05-07-2013, 12:55 PM   #2
Snowbound
Snowbound's Avatar
Re: 700r4 Swap
**my swap was a 200r4 but the basics should be the same**
You need to figure out the wiring inside the trans first, but basically to lock up the converter, you need 12 volt to the solenoid inside the trans.
How I did mine was:
-Keyed power through a vacuum switch to allow the converter to unlock upon acceleration.
-then run that wire from the vacuum switch to the brake pedal switch to allow for unlocking upon braking.
-then run the wire to the trans
I bought my TV setup through Bowtie Overdrive. I had to run a 1" spacer under the carb (Edelbrock carb) for the linkage to clear the intake.
You could make this as simple as you want. A simple toggle switch to engage the converter will work. Just don't forget to flip it! Lots of guys using the B&M lockup switch, which I think is speed controlled. I didn't like that, and went with the factory set up.
Good luck,
Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 05-07-2013, 02:10 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: 700r4 Swap
Avoiding writing a novel for a thread reply post, here are a couple of links that should provide some basic answers to your questions...and no worries about being a little confused, everyone has to go through the same process for a 700R4 conversion/installation. If you have any specific follow up questions after going through the info on these links, I'm sure we are all happy to help where we can:
http://www.700r4.com/tech/tcc/index.shtml
http://www.bowtieoverdrives.com/cata...BCAT&CATID=OA1
http://www.tvmadeez.com/article/index.php
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-07-2013, 04:33 PM   #4
doobiebro
doobiebro's Avatar
Re: 700r4 Swap
Here's another good link http://www.technicalvideos.com/what_year_700R4.phtml
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 05-12-2013, 07:02 PM   #5
ChevyJr
Junior Member
ChevyJr's Avatar
Re: 700r4 Swap
After taking out the Saginaw tranny, bell housing, blah blah blah I cannot get the new starter on properly. I chose a flex plate and starter from a 72 Caprice because I'm running a sbc 400. Anyone had any experience with this? My shimming skills must be terrible, because its still not sounding great. ANY help would be appreciated.
