Old 05-07-2013, 04:37 PM   #1
csdineley
csdineley's Avatar
SM465 Bell house
Hello
Today My wife and I pulled the engine and trans out of my parts truck. The downside is we broke the slave cylinder ear off the bell house, whoops! So is it possible to have it welded back on? Or should I hit up the junk yards?
csdineley is offline   Reply With Quote
Old 05-07-2013, 05:24 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: SM465 Bell house
It's possible yes. As I recall finding a Hydro bell housing is kinda hard for these trucks.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-07-2013, 05:41 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's a rare and valuable bell housing. I've been looking for one for about a year. They typically go for about 250 on eBay.
Old 05-07-2013, 08:17 PM   #4
Rubble
Is this the same bell housing on any hydraulic assisted clutch from 85 to 91 square body?I have never compared my 80 to the 86 before...
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 05-07-2013, 09:35 PM   #5
MalibuSSwagon
Its aluminum, so you should be able to find someone or a shop that can weld cast aluminum.
MalibuSSwagon is offline   Reply With Quote
Old 05-09-2013, 01:47 PM   #6
Jeepwm69
Guess later ones had a hydraluic clutch? My 83 will make you look lopsided when your left leg is twice as big as your right from pushing the clutch!
Jeepwm69 is offline   Reply With Quote
Old 05-14-2013, 11:10 PM   #7
csdineley
csdineley's Avatar
Think I've found at least one hydro bell house, maybe two at a local junkyard. Question is what would be the best / easiest way to remove them from the trucks? I don't think I'm supposed to bring any jacks or climb under the vehicles. Any suggestions?
Old 05-14-2013, 11:24 PM   #8
1774btcrew
1774btcrew's Avatar
There is no easy way to do it. You can get them out without jacks but not without getting under the vehicles. I have pulled two complete set ups recently. The crossmember is the worst to pull in my opinion. You can unbolt it and with some luck slide it back of the transmission mount and then unbolt the transmission from the bell housing and let it drop down on a tire. The rest is easy. I would look into getting yours welded. It will save you some time and headaches
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
