Old 05-10-2013, 09:34 PM   #1
JAG66
1987 Silverado 4 X 10 speakers
Rear behind the seat speakers missing in newly aquired 87 SWB, but the factory mounts and speaker grills are intact. Trying to stay as factory and stock as possible, so not looking to build speaker boxes.
Do after market 4 X 10 speakers bolt to the factory mount same as the original speakers?
JAG66 is offline   Reply With Quote
Old 05-10-2013, 10:25 PM   #2
pontgta
pontgta's Avatar
Re: 1987 Silverado 4 X 10 speakers
You can put these made by kicker or any other brand you like. very little to no modification(new screw holes)
Amazon.com: Kicker 4" x 10" KS Series Car Speakers (pair) 11KS410: Car Electronics
pontgta is offline   Reply With Quote
Old 05-11-2013, 09:13 AM   #3
JAG66
Are you saying it's required to modify screw hole locations in the mount and grill to mount the aftermarket speakers?
Old 05-11-2013, 12:27 PM   #4
pontgta
pontgta's Avatar
yes, possibly, I can not remember if i had to, but its just the speakers to the brackets, once mounted looks factory
Old 05-12-2013, 08:29 PM   #5
TDS-MN
agreed, I think that any screws you may need to add/move from the O/E speaker locations, are going to be behind the finish O/E grille, and you'll never know the difference.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 05-13-2013, 10:44 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
watch some tweeters may stick up higher then stock covers
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-13-2013, 06:04 PM   #7
beamn7
I used these but did have to space the stock cover out about a 1/2". They sound great.
http://www.kenwoodusa.com/Car_Entertainment/Speakers/4''_x_10''_Speakers/KFC-415C
beamn7 is offline   Reply With Quote
Old 05-14-2013, 07:27 AM   #8
Keith Seymore
Keith Seymore's Avatar
Thanks Pont -
What about the wiring? Do these plug right into the factory harness, or is some trickery involved?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-14-2013, 11:27 AM   #9
68longhorn
68longhorn's Avatar
its not stock but looks close enough for me and sounds great... http://67-72chevytrucks.com/vboard/s...d.php?t=570123
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 05-14-2013, 12:31 PM   #10
pontgta
pontgta's Avatar
Originally Posted by Keith Seymore View Post
Thanks Pont -
K
Keith there is some wiring involved, but i did not cut my wires. I just tapped in to them with these type connectors.
takes about 10 sec to tapp in and you are done. and when you want to remove just disconnect and wire is still in tact( just in case you find some NOS 4X10..)
Old 05-14-2013, 01:10 PM   #11
McSwine
McSwine's Avatar
I've got some of Bigblocks brackets as well. As you mentioned, it's not stock, but it's close and it give you a ton more options as well as better sound.
McSwine is offline   Reply With Quote
Old 05-14-2013, 02:11 PM   #12
Keith Seymore
Ok, thank you. Good thought.
K
1979-1986
1986 - 2019
