Old 05-16-2013, 04:53 PM   #1
Mrdsmoke420
Question 87 chevy silverado, steering column help
I have of questions regarding parts inside the steering column. My ignition cylinder will not go into the "lock" position. I replaced the ignition switch actuator with an ignition switch kit. I will post pics in less than 30 mins.. Just wondering if anyone would know what im talking about.
Mrdsmoke420 is offline   Reply With Quote
Old 05-16-2013, 05:02 PM   #2
Mrdsmoke420
Re: 87 chevy silverado, steering column help
i am needing to know if anyone else knows what this is and where it goes within the steering column.
Old 05-16-2013, 05:05 PM   #3
Mrdsmoke420
also, what is circled in the picture. that is supposed to come a little farther up than it is, to lock the steering wheel. but it is not coming up any further. i am confused on this and need help. and where the marker is on the outside of the housing where you see the "lock marker" is not lineing up correctly with the ignition cylinder.
Old 05-16-2013, 07:59 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
It's for the key in buzzer(thought it had a plastic bit too)
slides in the hole below the round part,where the cylinder shape is
that lock pin comes out to lock the wheel,it needs the"lock ring"
i know some disable that when switching to manual shifter
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-16-2013, 08:09 PM   #5
notallthere
The better half downloaded this to help me rebuild the column in the truck, Fiero and Chevelle. Probably one of the best ones that I have found.
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
Page 50 + 51 shows where the little metal clip goes.
notallthere is offline   Reply With Quote
Old 05-16-2013, 08:25 PM   #6
Mrdsmoke420
Thank both you guys alot! So what would be the reason i dont have a springback in the ignition cylinder?
Old 05-16-2013, 09:13 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
I think it can be installed "out"one click
I'd pull it back out turn the inside back (needle nose pliers)and see if it works
confirm it moves the NSS switch "right" on top of the coloum
great info there had not seen that pdf before only seen the one pic
John
Old 05-16-2013, 10:49 PM   #8
bigd65
bigd65's Avatar
I had a problem with my steering wheel lock, I just removed it, the shaft, the spring. Now it's really OLD SCHOOL.
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 05-17-2013, 03:18 AM   #9
Mrdsmoke420
Thanks alot everyone! Found out that the spring kept falling loose after installing the last housing peice.
Old 05-17-2013, 07:19 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
cool
John
