05-17-2013, 12:14 AM | #1 |
Square Body Coil Over install?
My baby is a full frame off so I have a fully powdercoated frame/ crossmember etc.
I really HATE the air ride that I put into the truck. Has anyone ever modifed their stock spring area and drilled the top of the spring cup and lower control arm to do a coil over in the truck? I know there are lots of cross member kits out there but funds are tight and I don't want to have to try and get the crossmember out etc. Any other thoughts on what to do other then just put coils in the front? Thanks guys....
Tim Baillie Installer/Designer/Fabricator Trick Factory Customs Company - www.trickfactory.com Personal - www.hzemall.com Instagram - @hzemall |
05-17-2013, 02:43 AM | #2 |
Re: Square Body Coil Over install?
Try the suspension durum on the site. I've seen one square converted to coil over but it was custom fabbed
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-18-2013, 12:46 AM | #4 |
Thats not coil overs is it looks like shocks and bags, and its not a square body is it?
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
05-18-2013, 01:20 AM | #5 |
your correct but it's the idea. struts and shocks are not really all that different, remove the part of the cross member that holds the springs and add an extension for the top of the strut where the xmember was
05-18-2013, 03:29 AM | #6 |
Take a look at http://67-72chevytrucks.com/vboard/s...d.php?t=266485 thats the only one i have seen done yet.
05-18-2013, 05:06 AM | #7 |
Yah that's the one I was looking for
05-18-2013, 07:33 PM | #8 |
Maybe it's a toyota?
05-18-2013, 07:58 PM | #9 |
Bingo !!!
That is what I am talking about Thanks
05-21-2013, 03:43 AM | #10 |
That picture up there is a s10 frame the a arms are from michigan metal works.They are wider for the 50s chevy truck frame swap so the wheels don't look sunk in.
