Old 05-25-2013, 05:18 PM   #1
SSC's76
No No
SSC's76's Avatar
so need a cheap solution for lowered truck and towing
Well after a few camping trips I've noticed my truck rides like crap I have a bel tech lowering kit with shackles and hangers the 3 4 sport kit. After grab ing some tables and chairs for my nephews gradation party today and parking the truck I decided to crawl up under there sure enough with the smaller trailer loaded with tables and chairs I'm riding on the bump stops. Any very cheap solution to this issue? Thanks
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-25-2013, 05:41 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: so need a cheap solution for lowered truck and towing
Cut off the bump stops and brackets. add bump pads to the frame. This will give more squat to get on the overload leaf.
Then Carry the heaviest stuff in the bed against the cab. Then the while suspension will do the work and not just the rear
Air shocks and shock support brackets will up your suspension height under load.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-25-2013, 08:42 PM   #3
wraprail
wraprail's Avatar
Air bags.
Best of both worlds.
wraprail is offline   Reply With Quote
Old 05-25-2013, 09:15 PM   #4
izzy_Britton
izzy_Britton's Avatar
Make sure that you have a complete spring pack under there and that no one removed springs in the past?
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-26-2013, 12:44 AM   #5
andrewmp6
I would trim or move the bump stops and get a set of helper bags for it.
andrewmp6 is offline   Reply With Quote
Old 05-26-2013, 10:32 AM   #6
SSC's76
No No
SSC's76's Avatar
Thanks for the suggestions the spring pack is complete this truck was my dads since new and mine for the past 14 years. The only thing in the bed on that picture above is just my truck box with a coupe of jack stands a suitcase tool kit and some random small tools probably weights with the box 70 pounds if that. Last night when we were loading back up while the trailer was empty i walked from the back to the front just my weight and had a friend watching the truck and when i got to about 2 feet from the fro t of the trailer were were on the bump stops.the trailer I have hooked up its about a 5x12 super light I think the tong weight is under 50 pounds.
Old 05-26-2013, 02:05 PM   #7
SSC's76
No No
SSC's76's Avatar
Well found some helper cool springs online for 43 bucks from advanced auto anyone tried those?
Old 05-27-2013, 09:54 AM   #8
SSC's76
No No
SSC's76's Avatar
Well went and got the springs have not installed them as of yet test fit one last night just to kinda see. Looks like I'm going to have to take the bump stop Mounts off as these look like they ride directly on the frame. I think it should be close to lowered height once the mount is off right now installed just riding on the mount it raised the one back half of the truck to about stock. Just gotta figure out how to remove the rivet with out my handy air chisel and divot cutter since it locked up in storage.
Old 05-27-2013, 10:13 AM   #9
1LowToy
I added a couple of spring leafs and did a flip kit. May take one out yet I'll have to see how it rides a little more. I'm sure it will handle a load. I did this as the stock springs were mush and the truck would lean to which ever side it pleased. No more lean, will hand a load and still low.
1LowToy is offline   Reply With Quote
Old 05-27-2013, 12:34 PM   #10
school boy
school boy's Avatar
Check this out what I did on my c10 for hualing
http://67-72chevytrucks.com/vboard/s...d.php?t=542343
school boy is offline   Reply With Quote
Old 05-27-2013, 10:46 PM   #11
SSC's76
No No
SSC's76's Avatar
Dang that looks good I wish I could find a setup like that. I still have not had anytime to install them been a busy day of getting the camper ready for camping season. Found a broke part on one of the beds spent all afternoon fixing that in 90* heat I'm beat hopefully I may be able to do so w work tomorrow
Old 05-28-2013, 07:57 AM   #12
Rich84
Rich84's Avatar
I'd say that your leafs must be very tired..New leaf springs and you should be able to tow that light trailer no problem. I just had 800lbs of hardwood flooring in my truck with a flip kit and I was still about 2.5" away from the axle with bump stops removed.
Rich84 is offline   Reply With Quote
Old 05-28-2013, 09:40 AM   #13
DREAMER1
DREAMER1's Avatar
New leaf springs, and air shocks for back up.
DREAMER1 is offline   Reply With Quote
Old 05-28-2013, 09:03 PM   #14
Blackpony
Blackpony's Avatar
where is a good affordable place to buy new leaf spring packs for these truck?
Blackpony is offline   Reply With Quote
Old 05-29-2013, 08:37 AM   #15
SSC's76
No No
SSC's76's Avatar
Well I got the helper springs installed. Spent some time cutting the bump stop perches off last night always fun. Well ride height was effected the rear end is up about an inch and a half. At this point I could cut so e of the helper coil off but I will just leave it for now. I don't think the leaf springs are to worn I think the beltech hangers allow more squat and flex. For a $35 option these springs work real well the ride in the truck is a lot smoother so just need to get a load in her for the real test
Old 06-15-2013, 08:12 PM   #16
SSC's76
No No
SSC's76's Avatar
Well got an update preparing for camping this week got the camper on the truck. Looks like I'm going to have to dump the 4 inch raise hitch and maybe find a 2 camper sits a little odd. I did take it for a short trip up to road and it is so much smoother and funny thing is it feels like it pulls easyer to might just be cause the ride isn't rough at all anymore.
