Old 05-27-2013, 04:28 AM   #1
jon75
jon75's Avatar
LS swap options
Hey everyone. After reading several build threads with the LS (gen IV and up) engine swaps, I have some curiosity questions. I'm not quite sure of all the specifications of my truck, but I do know a couple. I know that the engine makes 160 horsepower and 255 ft-lbs of torque. What I find odd is that the transmission and transfer case don't seem to be anything special compared to today's items. I mean, a GM 4.8L V8 makes more power than that. But here is what I was thinking.....
I have a 4x4 so I only want to mess around with things one time. I want the engine, trans, and case to all be from the same vehicle or setup. So that rules out Denali and Escalades unless I swap in a different case. But what I would like is to put in a 5.3 with a 4l65E and NP241 case. I know just about every nook and cranny of these components so I know what to do before I swap them in to make for an awesome, long living combination. If the deal was right, I would go with a 6.0 with 4L80E and NP243 case, but it's a lot of extra weight in those components and I'm unsure if it would be worth the extra pounds and cost.
Let me know what you guys think....
1975 GMC Sierra Grande K25HD 350-4BBL 4sp LWB
2009 Infiniti G37S Sedan w/Stillen sway bar kit & K&N Typhoon dual snorkel intakes
ASE certified for brakes, electrical diagnostics and heating and A/C & EPA certified in R12 and R134a
jon75 is offline   Reply With Quote
Old 05-27-2013, 07:52 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: LS swap options
Sounds like you have a solid plan. Unless you plan on swapping out the front axle you are going to need a NP241 case from a 90-91 Blazer or Suburban. If you are going to swap out the front axle you need one from a 77-79 Ford F250 or F350 for a direct bolt in.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-28-2013, 03:24 AM   #3
jon75
jon75's Avatar
Re: LS swap options
Why do I need to either swap the axle or get a specific case? Is that strictly so it all bolts together with no driveshaft work? If so, I would rather have my driveshafts done rather than stick in a 25 year or 35 year old part. Thank you for the information!
Old 05-28-2013, 07:27 AM   #4
cletis
cletis's Avatar
Re: LS swap options
Late model Chevys has a drivers side drop on the t case, that is why you require a Ford front axle or a 2 year only t case.
I think I can, I think I can,
http://67-72chevytrucks.com/vboard/s...d.php?t=452601
cletis is offline   Reply With Quote
