Old 05-29-2013, 01:08 PM   #1
jerrysoldtrucks
67 suspension and brakes
hello, i m a new guy here. old guy everyplace else(born 1941). got a 67 with drums and a 71 withdisc. want to use 72 spindles out, all steering linkage. no a frames. shud i just replace all 4 ball joints with 72 and be done with it. any other help will be appreciated. Jerry MGYSGY USMC ret (1984):gmc
jerrysoldtrucks is offline   Reply With Quote
Old 05-29-2013, 04:51 PM   #2
tmc1986
Re: 67 suspension and brakes
first off, SEMPER FI!!!! second, yes, i do think you should replace all the ball joints. i believe the ball joints are all the same with the 67-72 1/2 tons. i was putting a 4.5/6in drop and power disc brake conversion on my 67 with the 71'+ spindles just the other day. i replaced everything i could when i took the front end apart. upper and lower ball joints, tie rod ends, bushings. a lot of the stuff was original because it still had factory rivets on the upper ball joints.
'67 2wd LWB 350/4speed.
tmc1986 is offline   Reply With Quote
Old 05-29-2013, 05:38 PM   #3
67c10rustbuket
67c10rustbuket's Avatar
Actually the ball joints, inner & outer tie rods, and center link are different. They changed in 71 with the change to disk brakes. If you are using oe parts from a 71-72 make sure you get the center link! Another option is to buy disk conversion spindles in either std height or drop. This way you keep using 67-70 ball joints and tie rods. No surprises, returning parts and headaches.
Ps- semper-fi! from a marines brother
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-29-2013, 06:22 PM   #4
ole dollor
ole dollor's Avatar
first let me say welcome to the forum from Texas, and my wife says Simper-Fi to you , she is a ex Marine sister...i guess.
ole dollor is offline   Reply With Quote
Old 05-29-2013, 06:50 PM   #5
SS Tim
SS Tim's Avatar
There are a number of ways t upgrade your front end and I'd recommend starting with this link.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Like others have said the 71-72 dics parts are upgraded and I would recommend using factory upsized parts vs adapter parts found in some kits. Might think about using later 73 up rubber bushed arms as well.
SS Tim is offline   Reply With Quote
Old 05-29-2013, 07:03 PM   #6
jerrysoldtrucks
thanks to you all. SEMPER FI!
