Old 05-30-2013, 11:09 PM   #1
Houston Ben
Houston Ben's Avatar
5.3 with 6L80 swap?
Hi all,
I am going to be swapping a 2011 5.3 with 6L80 attached into an 86, I see v502 had this done but does anyone know if the engine sat in the same place as the original place or did he have to buy mounts that moved it forward or backwards?
Also, does the trans cross member need to be lower for the tranny to fit in place?
Anything I need to be aware of for the swap?
Thanks!
Houston Ben is offline   Reply With Quote
Old 05-30-2013, 11:14 PM   #2
85burb
85burb's Avatar
Re: 5.3 with 6L80 swap?
Look in to the ls swap area in the drivetrain section. Just about all the info you will ever need.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
