Stumped an need help on electronic speedo & 700r4
I've got a 1986 c10 that's carbureted and I recently had a 700r4 out of an 89' Chevy truck and it has electronic speed sensor instead of cable, so I found an instrument cluster out of a 90' suburban with an electronic speedo but now I'm not sure how to get it to work since they say it needs a DRAC but with my truck being carbureted it dont have a PCM so how can I get the electronic speedo to work?
Posted via Mobile Device |
#2 | |
Re: Stumped an need help on electronic speedo & 700r4
i may be wrong but i do not think you can use the e-speedo. however you could just change the gear on the tail housing to the manual speedo gear and be done with it. if you do get the e-speedo working i would very much like to know how. i also have an 86. -Izzu Posted via Mobile Device
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
Izzy is right, the easiest thing to do is pull the tail housing off and take the reluctor ring off of the output shaft and install a speedo gear. You will also need a speedo cable drive for the tail housing to go in place of the speed sensor. Good luck.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD ![]() 1970 Chevy Nova - Street and Strip Project ![]() 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
Thanks for the input. There has got to be a way I can make this work. If I bought an autometer speedometer an just connected it to the speed sensor wires would it work properly I wonder?
#5 | |
one prong was ground and the other was the signal wire. Now my nv3500 has a 3 prong and I cant get it to work lol. Another option is this http://www.abbott-tach.com/cablex.htm
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
I too would like to hear some ideas. I have a T56, don't mind changing my speedo but dont want to spend a bunch of money. 85 c10 no computer
Addicted to Rust
![]() Join Date: Dec 2009
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
#8 | |
You can use an VSS and electronic speedo without a ECM/PCM.
Thanks a bunch MalibuSS! I happen to have one of them trucks at my yard that's crashed, I'm gonna try that out!! I will let y'all know the results!!
Malibu do you know if it matters if the truck is a diesel or gasoline?
I don't think it would matter, since all 88-98 trucks used an electronic speedometer. If it's a 92-95, and has the white box you should be ok.
There is a unit called Cable-X it converts the electronic signal to mechanical . Runs about 300 and comes with a new short speedo cable. This keeps the stock dash and speedo.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
#13 |
![]() Join Date: Dec 2012
They make gps speedos now Dont have to hook to trans at all
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
#14 |
another source....jagsthatrun.com a call or check out their webpage
http://jagsthatrun.com/Pages/SpeedSe...eedometer.html |
| Bookmarks |
