Old 06-03-2013, 08:23 AM   #1
chuychevy82lwb
bondoing the tailgate trim ?
So like most of us with the brushed aluminium tailgate trim we have dents or something making it less then perfect so I question to anykne who has done it its it possible to bondo the imperfections and then paint it will it look good or sjould I not even try it ?
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good "
chuychevy82lwb is offline   Reply With Quote
Old 06-03-2013, 08:45 AM   #2
andrewmp6
Re: bondoing the tailgate trim ?
It has a coating on it its either anodized or clear coated,Once you get the coating off you can paint it tho.
andrewmp6 is offline   Reply With Quote
Old 06-03-2013, 08:50 AM   #3
chuychevy82lwb
Yea thoes are my intentions man I have some left over paint but I wana just c if it will look good b4 I do it
Old 06-03-2013, 01:08 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
It's a thin metal that may crack the bondo ESP when you shut the tailgate. I would hammer it out and use as little as possible. Research different fillers and see what you kind find that will work the best.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-03-2013, 01:52 PM   #5
ont_guy_38
ont_guy_38's Avatar
I haven't did any bodywork for quite a few years now, but I wonder if you remove as much of the ding as possible,prepare, epoxy prime the trim and them use some 2 part putty if that would be safer. I would ask this to get moved to the body and paint section if I were you.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 06-03-2013, 01:58 PM   #6
chuychevy82lwb
Its not hella baf to were I'd use a lot but its nowere perfect either but do ya thibk it wo Yuri ld work now I have a concern cuZ even that its very little that I use my tailgate I don't what pieces coming off after iys been painted n cleared
Old 06-03-2013, 06:16 PM   #7
74 stepside
74 stepside's Avatar
Your posts are a little hard to read. Might want to proof read them before you post. As far as the tailgate piece, try out a body hammer and dolly before you start with body filler (bondo). They will smooth out the majority of the dents. Good luck..
74 stepside is offline   Reply With Quote
