Old 06-03-2013, 07:44 PM   #1
chris1htx
start like new
can somebody give me some options on how i can get my 84 c10 to start like new? like most older trucks i have to pump the gas a little to get the truck started, looking for some suggestions
chris1htx is offline   Reply With Quote
Old 06-03-2013, 07:51 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: start like new
Most trucks require pumping the gas a little when it is first started for the day.
Is your choke hooked up? Do you set the choke before you try to start it?
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-03-2013, 08:30 PM   #3
lilpoindexter
lilpoindexter's Avatar
Re: start like new
Switch to fuel injection
lilpoindexter is offline   Reply With Quote
Old 06-03-2013, 09:07 PM   #4
StarDust
StarDust's Avatar
Re: start like new
well what i replaced on my truck was the fuel pump and the starter used to take ALOT of gas pumping and hitting the switch to get it to start now i dont even pump the gas just turn the switch for like 2 secs
StarDust is offline   Reply With Quote
Old 06-03-2013, 09:49 PM   #5
bilfman
bilfman's Avatar
Re: start like new
I put on a new edelbrock with electric choke . Starts like new!
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 06-03-2013, 10:03 PM   #6
Mikec10
Mikec10's Avatar
Re: start like new
yeah I have a nice edelbrock carb, starts like new. Honestly fires up quicker then my 07 impala with electronic ignition.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 06-04-2013, 12:30 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: start like new
It's carbed. You have to pump when it's cold to get fuel in to start. Fuel injection has cold start injectors or fires the injectors once when cranked. Today's gasohol fuels evaporate out of the carbs alot quicker as well. Drains the fuel bowls quicker
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
