Old 06-04-2013, 08:23 PM   #1
contagious102
contagious102's Avatar
Notched firewalls
Putting a 540ci in my 66 step,and the valve covers are hitting the firewall.Lets see pics of notched firewalls.I have to use the tall valve covers ,because i run a stud girdle with the 760 lift cam. Seen a few on here before.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 06-04-2013, 10:56 PM   #2
62-One-Ton
62-One-Ton's Avatar
Re: Notched firewalls
Only based on seeing/personal preference here but. Can the motor be moved forward enough to not need to tub/notch the firewall? If it can't due to radiator clearance or possibly transmission woes I understand but I personally never cared for the look of any firewall other then stock or smoothed out. The tubbed/notched ones never have that "factory flow".
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135
'62 C10 SWB
'03 Express Van 5.3l Dead (parting out and using motor)
'99 Silverado 4.8l 5 speed 4wd
62-One-Ton is offline   Reply With Quote
Old 06-05-2013, 12:02 AM   #3
RockTonka
RockTonka's Avatar
Had to set a BBC back a bit in our burb...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 06-05-2013, 09:29 AM   #4
contagious102
Nice job on that RockTonka,that's about what i need to do.Thanks.!!
Old 06-05-2013, 11:55 AM   #5
gofastnut
gofastnut's Avatar
Hey Rocktonka,
Can you still remove the valve covers?
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 06-06-2013, 12:20 AM   #6
RockTonka
RockTonka's Avatar
Originally Posted by gofastnut View Post
Hey Rocktonka,
just barely...
My build thread
Old 06-06-2013, 01:14 AM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
I cut mine in 3 spots then bent the firewall back and welded in some sheetmetal. Like the other the valve covers barely come off but they do.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-06-2013, 08:28 AM   #8
da_bears_da1
Good to see these solutions. I will be notching mine next week. My new roller rockers will only fit under the tall valve covers. I have about a 1/8" clearance to the firewall so notching is my solution.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
Old 06-06-2013, 11:25 AM   #9
BRASSHEAD
BRASSHEAD's Avatar
I notched mine like the above the first time around and just didn't like it.
I then cut out and recessed the center section with a custom made piece.
BRASSHEAD is offline   Reply With Quote
Old 06-06-2013, 11:37 AM   #10
61K10
61K10's Avatar
Now thats the way to do it!! nice job BRASSHEAD-------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-06-2013, 11:41 AM   #11
contagious102
That's slick.!!!
Old 06-06-2013, 09:15 PM   #12
gofastnut
gofastnut's Avatar
Brasshead, that's REALLY nice! I've got a 454 that's goin in Ole Brownie and I was curious about that.
Jeff
C-10 Club
Old 06-09-2013, 12:35 AM   #13
BRASSHEAD
BRASSHEAD's Avatar
Thanks guys
Old 06-09-2013, 12:55 AM   #14
Bomp
Bomp's Avatar
These modifications were done because I moved the motor back, did away with the 'gutter', shaved/filled most of the holes.
Here is a look at the inside of the firewall under the dash.
You will see the floor is different than stock infront of the trans tunnel cover because the cab was also stretched 5".
Second pic shows how much room between header and cab before completion.
Bomp is offline   Reply With Quote
Old 06-09-2013, 11:20 AM   #15
contagious102
Finished mine this morning,went big just in case.!!
