View Poll Results: What is your average fuel mileage (US gallons)
Less than 10MPG 7 13.73%
10-12MPG 14 27.45%
12-14MPG 8 15.69%
14-16MPG 8 15.69%
16-18MPG 9 17.65%
18-20MPG 5 9.80%
More than 20?! 1 1.96%
Multiple Choice Poll. Voters: 51. You may not vote on this poll
Old 06-05-2013, 09:01 PM   #1
66Submarine
66Submarine's Avatar
Question Fuel economy poll
I'm curious. What kind of fuel consumption are all you guys seeing in your 60-66? I think it'd be neat to have a poll. Post your numbers, along with a basic description of the truck and driveline. Should be interesting.
EDIT: Also, note how you calculated the mileage.
66Submarine is offline   Reply With Quote
Old 06-06-2013, 09:04 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Fuel economy poll
get 15 city and 20 hwy, with my LSx motor and OD trans.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-06-2013, 10:29 AM   #3
1963c-10
1963c-10's Avatar
I calculate my mileage off number of miles driven divided by gallons purchased. Factory unrebuilt 230, 3sp trans and 12 bolt rear end. 235/75R15 tires 12-14mpg. Motor is starting to get tired and Im guessing the rings are starting to wear some after 51 years, so I expect a few miles per gallon lower than most with the same drivetrain that has been rebuilt or replaced.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-06-2013, 10:45 AM   #4
Rich 5150 69
Rich 5150 69's Avatar
quad fed vortec 350/350.3.73 gears, 28 inch tall tires, 17 MPG..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-06-2013, 10:53 AM   #5
jimmydean
jimmydean's Avatar
I think my '66 got about 8, but it's been a while since I drove it.
My '92 gets 17mpg city/hwy/on fire falling off a cliff.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-06-2013, 03:02 PM   #6
64fleetside
64 SWB using 350/350, get 16mpg. I use the same station/pump, calculate gallons used and divide into mileage traveled. My old black truck was a stock 230/3 spd, also got 16mpg as long as I kept below 65mph or so.
64fleetside is offline   Reply With Quote
Old 06-06-2013, 05:05 PM   #7
theastronaut
theastronaut's Avatar
29.5 city/highway mix, never under 28.5 no matter how hard I drive my '64.... VW Bug.
My '66 truck actually uses no gas at all- it is very green/environmentally friendly. 100% human power any time it moves.
theastronaut is offline   Reply With Quote
Old 06-06-2013, 06:06 PM   #8
ChuckW
ChuckW's Avatar
Pretty sure I'm hovering around 8ish gpm.... I had hoped for maybe 10...
ChuckW is offline   Reply With Quote
Old 06-06-2013, 09:10 PM   #9
gofastnut
gofastnut's Avatar
About 7mpg....found out my fuel pump is taking a dump--literally. Let ya know when it's running again.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 06-06-2013, 09:48 PM   #10
Indian113
Indian113's Avatar
If it was my DD I'd worry about mpg. But I worry more about SMILES PER MILE!!!!
Indian113 is offline   Reply With Quote
Old 06-06-2013, 10:58 PM   #11
66Submarine
Interesting results so far, everyone.
Mine IS my daily driver, I want it all! I can feel better about my 14MPG one ton now, though, after today. It doesn't get what my half ton would, but I went to a buddys place today to see about a leaking intake on a hot rod BBC Camaro. The guy with the Camaro wanted a "hot rod like you guys used to have in the 80's". NA 461BBC with a .741 lift roller cam, giant Holley dominator on a single plane intake, and 15:1 compression. He is trying to drive it every day. 3-4MPG on race gas. I think he said he was paying $600 or something for a drum.
Old 06-06-2013, 11:32 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
Last time I checked many years ago I was getting around 15-17. With a brand new engine and a cam I have no idea what it gets now. I suppose I don't really care that much anymore as I'm retired and the truck is just for fun.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-06-2013, 11:39 PM   #13
jonathan-m
10-11 mpg from Florida to Az hauling all of this stuff . 350 sbc automatic transmission. Calculated by hand.
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
Old 06-06-2013, 11:58 PM   #14
donthekawguy
donthekawguy's Avatar
I'm getting around 7 mpg.
66 shorty
donthekawguy is offline   Reply With Quote
Old 06-07-2013, 12:53 AM   #15
pestwagon
leaky quadrajet on vortec headed 350, 350 TH and 3.73 posi with 255 60 15s (27 inch tires) getting 9 on freeway going 70...
recently put a good performer carb (edelbrok) 500cfm, will calculate new mileage and am running ported manifold vacuum to advance on the distributor and normal (unported) manifold vacuum to the transmission.
pestwagon is offline   Reply With Quote
Old 06-07-2013, 06:36 AM   #16
Sharps40
pullin 15 to 16 combined city/highway with a rebuild 230 I6 in a 65 C10. Using HEI and a Weber DGEV carb. Still tuneing and mileage increasing with each tweak to jetting. Hopeing for 18 to 19 when all finished but that might be optimistic with a factory 3 speed and 3.73 rear.
Sharps40 is offline   Reply With Quote
Old 06-07-2013, 10:13 AM   #17
vpersh
vpersh's Avatar
c20/350/700R4/3.53:1/GM TBI: 11-12 around town; 13-14 on the highway if no head wind.....
Van Pershing
Tucson, Arizona
Idea Page
vpersh is offline   Reply With Quote
Old 06-07-2013, 10:55 AM   #18
newbe351
I had a '75 Dodge Power Wagon that got 12 mpg in the city, on the highway, off-road, on-road, sitting in the driveway. Never varied.......
newbe351 is offline   Reply With Quote
Old 06-07-2013, 01:47 PM   #19
Clyde65
Clyde65's Avatar
Back in the late 80's I had a 72 GMC C20 with 1 ton rolling chassis, it had a 400/400 and got 10MPG fully loaded or empty. I even had it pulling a goose neck 2-car hauler and it got 10MPG period.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-07-2013, 06:31 PM   #20
argonaut
argonaut's Avatar
1964 C10 SWB, 350 (mild cam, quadrajet, manifolds-dual exhaust), TH400 (shift kit), 3.73:1 12-bolt, 31x10.5R15 = 13mpg (averaged total miles per fill-up over hundreds of trips mixed driving)
1964 C10 SWB, 402 (stock), TH400 (shift kit), 3.73:1 12-bolt, 31x10.5R15 = 11mpg (averaged total miles per fill-up over dozens of trips mixed driving)
1966 K20 SWB, 402 (stock), SM465, NP205, 4.11:1 14BFF+D44, 35x12.5R16 = 12mpg (hoping, wishing, dreaming!)
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 06-09-2013, 01:54 PM   #21
Ronchy
My truck is a '65 GMC 1500, 305 V6 with HEI, Holley 500 2BBL, single 2 1/2" exhaust with Magnaflow muffler, SM420 and 4.10 axle. I have spent a lot of time tweaking the carb and ignition advance curve.
The best I have done is 16 MPG empty at 60 MPH. I have never checked the "around town" mileage.
I usually haul a 8 1/2' camper, and weigh 7100 on the scale. I can get up to 11 MPG with camper if I keep it at 50 MPH or less on the mountain roads, but if I need to do 60 - 65 because of traffic, it drops to 8.5 to 9 MPG.
Ronchy is offline   Reply With Quote
Old 06-09-2013, 03:38 PM   #22
cortcomp
cortcomp's Avatar
On the way home from fresno to near youngstown, Ohio, 66 LWB 327, factory everything, 3.73, 80K original miles, doing 70MPH by gps all the way (75MPH according to speedo) we got 12-13MPG steady. However, with that 4BBL and tiny primaries, i bet just staying around/under 55mph for a day would get you massive savings, like 15MPG. We were into the 4 barrels pretty much the whole time i think. Also, we were leaking fuel and sucking air into one of the fuel pump lines some, so maybe that cost us a single mpg or something.
I'm hoping with the engine rebuild (stock so low rpm torque band), and OD to bring the RPMS down, and new carb rebuild, fuel pump, etc. that i can squeeze pit 15-18 steady if i drive casually.
My '07 1500 6.0L 1/2 ton 2wd crew cab gets 15 no matter what, and that's with it turning half the cylinders off on light cruising and coasting!
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 06-09-2013, 05:31 PM   #23
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Think mine gets around 15 or maybe got around 15.... 49 years ago! With 150,000 miles on it now it no doubt gets a little worse mileage than before.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
