Old 06-23-2013, 08:35 AM   #1
jbgroby
jbgroby's Avatar
Attenna Mount
I'm trying to mount the antenna to the P/S cowl and am finding it impossible to get the new antenna mount to hold. I bought it from LMC (which I'll assumes gets them from a far east country) In the pictures below which show the "crown" for lack of the proper name, when I tighten the top nut which compresses the crown downward it deforms the gasket/bushing to where it slips off the crown.
In order to attempt a quick fix, I roughed up the bottom of the crown with a dremel tool and put some crazy glue to hold the gasket in place, I'l see how this works later.
Anyone else have this happen?
jbgroby is offline   Reply With Quote
Old 06-24-2013, 01:56 PM   #2
64fleetside
Re: Attenna Mount
Chinese stuff is junk, IMO-I ended up buying an American made repro antenna off EvilBay.
64fleetside is offline   Reply With Quote
Old 06-24-2013, 02:04 PM   #3
jbgroby
jbgroby's Avatar
Re: Attenna Mount
I used some ACC glue kak "Crazy Glue" to hold the gasket in place. Came out OK, will look for a different mount later.
You woud lthink for $89.99 you'd get something better.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=74
Part number 38-1146
Old 06-24-2013, 04:05 PM   #4
Vernski
Re: Attenna Mount
Part number 38-1146
I don't know where this is made but it mounted w/no problems..Vernski
http://www.classicparts.com/searchprods.asp
Vernski is offline   Reply With Quote
Old 06-24-2013, 05:46 PM   #5
bhc41051
bhc41051's Avatar
Re: Attenna Mount
x2 On Classic Parts
1. They're almost always cheaper than LMC. Classic wants $64.95 for a 60-62 antenna LMC wants $89.95 for a 60-62 antenna.
2. If you order online and use "Stovebolt" as a discount code you'll get 5% off
3. Classic Parts doesn't use those annoying packing peanuts.
bhc41051 is offline   Reply With Quote
Old 06-24-2013, 06:49 PM   #6
jbgroby
jbgroby's Avatar
Re: Attenna Mount
I got I mounted Ok after gluing the gasket on, although it leans in a bit, It will work until I find a replacement.
