Old 06-25-2013, 11:50 PM   #1
jorgensensc
jorgensensc's Avatar
WTB: Seat belt bolt
Hey all! Got the third row installed in the suburban but I am short 1 seat belt bolt that mounts to the seat brackets. I think all of the seat belt bolts are the same though. Price shipped to 91208 please. Thanks!!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-26-2013, 11:53 AM   #2
blessedfind
Re: WTB: Seat belt bolt
I think I have an extra one I will give you. $3.00 should cover shipping from NC to CA. Could you give me a length on it to make sure I do send you the right one.
blessedfind is offline   Reply With Quote
Old 06-26-2013, 03:01 PM   #3
budnikguy
budnikguy's Avatar
I could help ya...going to Brother's show?!
budnikguy is offline   Reply With Quote
Old 06-26-2013, 05:40 PM   #4
kcsa75
kcsa75's Avatar
The easiest thing would be to head down to your local Ace or True Value and get a Grade 8 bolt. Shouldn't be more than a couple bucks.
When I replaced the seatbelts in my pickup I wanted to replace the bolts too, but I came up one or two bolts short. A trip to the hardware store and I was good to go.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 06-26-2013, 10:39 PM   #5
jorgensensc
Hey guys. Thanks for the replies! Sorry for the delay. I was just finishing up the fuel lines on the ls swap in the suburban. They come to tune it tomorrow evening and then to the exhaust shop to connect the old to the new. Then I'm done with the burb for the moment. I'm not sure on the length. I will check that later. When is the brothers show? I was going to get the bolts from the local hardware store, but would prefer the correct ste bolt with the collar for the seatbelt.
Old 06-26-2013, 11:02 PM   #6
budnikguy
budnikguy's Avatar
https://www.facebook.com/brotherstrucks
Old 06-27-2013, 11:39 AM   #7
camrycurt
camrycurt's Avatar
I think I have one too that you can have if the other guys don't work out.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 06-27-2013, 01:39 PM   #8
jorgensensc
Thank you guys!! Y'all are awesome. I will get the dimensions. I want to go to the Brothers show this weekend, but I'm just not sure if I can make that happen.
Old 06-29-2013, 01:02 PM   #9
cheyenne shortstep
cheyenne shortstep's Avatar
I would recommend using the correct OE seatbelt bolt as it will fit the belt end properly. Other than rust the originals should be just fine as far as integrity.
cheyenne shortstep is offline   Reply With Quote
