Old 07-05-2013, 07:32 AM   #1
lo72
Truck Junkie
lo72's Avatar
85 C10 Long Arm Suspenion
Looking to replace the rear leaf suspension with 67-72 long arm suspension using some Porterbuilt parts. Will be piecing it together not able to buy the whole setup. Question does anyone know if the long arm crossmember can be installed without removing the cab? Will b bagged front and rear. Any input would be great. So bags on the arms or on the axle, behind the axle, in front of the axle inside the frame or outside the frame? Dominators or rolling sleeve bags? Thanks for the input. Greg
lo72 is offline   Reply With Quote
Old 07-05-2013, 11:20 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 85 C10 Long Arm Suspenion
I would use the design that Nate Porter has developed.
He has this figured out.
http://www.porterbuiltfabrication.com/?p=409
He uses a double convoluted bag on the arm.
This keeps everything under the bed floor.
I suppose if you step notched the rear frame, you would want to use a sleeve bag connected to the rear axle.
Keith
Convert to disc brakes.
Old 07-06-2013, 12:15 AM   #3
chopped68
all of the rear suspension work can be done with the cab on.as far as the bags go,it depends on how low you want the truck to sit.a step notch will limit how low it can be.
chopped68 is offline   Reply With Quote
Old 07-06-2013, 10:45 AM   #4
lo72
Truck Junkie
lo72's Avatar
Thanks for the input, based on Porterbuilt's website I'll go with the ss7 bags on the arms, my biggest worry was installing the crossmember without removing the cab, I don't have the space or help available to do it safely. Thanks again Greg
Old 07-07-2013, 02:38 PM   #5
blazins10
blazins10's Avatar
i removed mine with cab on , it sucked but it came out ,
easiest way is too cut your stock crossmember out first then go after the rivits
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 07-07-2013, 07:00 PM   #6
lo72
Truck Junkie
lo72's Avatar
Thanks for the input, my truck is an 85 and I don't have the crossmember. I'm changing the suspension over to the long arm type.
