Old 07-05-2013, 09:41 AM   #1
Sodell
Sodell's Avatar
Rear drop shocks/use front?
Has any one used front shocks for the rear? I have about 4-5 drop in rear and I have heard of using the front shocks for the rear. Looking for some advice. ride quality ect?
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 07-05-2013, 10:05 AM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Rear drop shocks/use front?
I've used fronts on the rear and they worked fine,
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-05-2013, 10:09 AM   #3
Sodell
Sodell's Avatar
Scott
Old 07-05-2013, 11:20 AM   #4
cory d
cory d's Avatar
i have front shocks on my rear with the mounted to the u-bolt plate. being front shocks and with the steeper angle, they are too dampening.
cory d is offline   Reply With Quote
Old 07-05-2013, 11:21 AM   #5
cory d
cory d's Avatar
but thats with monroe gas magnums. monro sensa-tras should yield better results
Old 07-05-2013, 08:28 PM   #6
Sodell
Sodell's Avatar
Cory, you running a flip kit
Scott
Old 07-05-2013, 10:51 PM   #7
Claytona08
Claytona08's Avatar
Hey Sodell, haven't seen you on lately. I'm running DJM shocks. 2100 on the rear and 1309 on the front.
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 07-05-2013, 11:38 PM   #8
Sodell
Sodell's Avatar
Clayton, you using the flip kit with shock extenders?
Scott
Old 07-06-2013, 12:47 AM   #9
meatwagon83
meatwagon83's Avatar
i used 79 toyota truck shocks on mine when it was lowered
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 07-06-2013, 07:53 AM   #10
Claytona08
Claytona08's Avatar
Yeah I got the flip kit with the shock extenders. The extenders came with the kit I purchased. You can probably order a set fairly cheap. I think the flip kit was only 80$ for the whole kit from Summit so I would think the extenders couldn't be more than 35$.
