07-07-2013, 09:18 PM | #1 |
Carpe manana
Anyone have OEM Auxiliary Battery (RPO TP2) or Rear Seat Center Belt (RPO A68)?
Would like to see SPIDs and/or photos of Blazers w aux batteries or rear seat center belts. Did 72 K5's w a rear seat come standard with two belts? Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
07-07-2013, 09:48 PM | #2 |
Re: Anyone have OEM Auxiliary Battery (RPO TP2) or Rear Seat Center Belt (RPO A68)?
While trying to identify correct duel horn setup, I ran into this post that had a picture of an aux battery tray. Thought it would help ya.
http://67-72chevytrucks.com/vboard/s...=horn+location -Jim |
07-07-2013, 11:18 PM | #3 | |
Carpe manana
07-07-2013, 11:56 PM | #4 |
I have an aux tray as well. Pm for pic if needed
Posted via Mobile Device |
07-08-2013, 06:43 AM | #5 |
Do you have a pic. of where the relay is mounted on the inner fender. Just bought a set up from Koop and not sure where it is mounted up....thanx
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
07-08-2013, 08:16 AM | #6 |
Carpe manana
The relay doesn't mount to the inner fender in the OEM set up. It mounts to either the tray or rad support - can't remember exactly which but certain it isn't the inner fender. I'll see where we mounted the relay on my K20. Here's a pic that shows the J-block on the fender:
07-08-2013, 06:30 PM | #7 |
Back in the sticks
If I remember correctly, it mounts to the core support, next to the regulator. If I had my assembly manual, I would look it up for you, but its at home...
That is where I put mine when I installed the aux battery.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
07-08-2013, 08:45 PM | #8 |
Thanks guys for the tips....ill check out my manual
07-08-2013, 09:33 PM | #9 |
My '72 Jimmy had the center rear belt, but it was not on the SPID. It had AM/FM and cruise control, and that was not on the SPID either. We got it used in '77 so previous owner may have had dealer add?
It has aux batt tray now, but I added that.
07-09-2013, 12:30 PM | #10 |
Just looked at the aux. tray, does have holes in the side, but none seem to line up exactly for the relay
07-09-2013, 12:41 PM | #11 |
Carpe manana
Those holes are for the voltage regulator and originally had rubber grommet inserts....
07-09-2013, 12:44 PM | #12 |
I had (have been since sold) the center rear belt as well as front and rear shoulder belts, on the SPID as 4A85AG.
07-11-2013, 11:04 AM | #13 |
Dam, youre right, it does fit there! Now i just have to buy the isolaters
07-12-2013, 06:20 PM | #14 |
Carpe manana
So my 72 K5 has a center rear seat belt but this isn't listed on the SPID. Did all 72's w a rear seat get a center belt?
