Trans leak question
I picked up a th350/203 to replace my junk trans. It looks like its leaking where the tc bolts to the trans, is this just a unbolt, clean up and rtv deal?
Posted via Mobile Device |
#2 | |
Dino burner
Re: Trans leak question
At the front of the transmission, there are a number of places where it could be leaking: - the torque convertor to front pump seal - each bolt that holds the front pump to the transmission case has a small seal on it - pump to case gasket - o-ring seal between the pump halves that also seals to the case - transmission fluid pan |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I figured he meant transfer case.
It is leaking where the transfer case adapter bolts to the transfer case. Just wondering if I need to find a gasket, or if rtv will work here.
| Bookmarks |
