07-17-2013, 12:46 PM | #1 |
more k5 floorpan help
Im having various work done on my '70 and while its there, im having floor pan work done. I know they dont re pop the full pan for a k5 but will a full truck pan work? What problems are there with doing this. I dont have pics to post as its at the shop. My problem is the drivers side is bad front and along the rocker/seat platform Pass side is good in the front but is bad under the platform. Im thinking it would be just as good to replace it all.
Posted via Mobile Device |
07-17-2013, 02:38 PM | #2 |
Re: more k5 floorpan help
I would have the cut out work done and removed first to see what your looking at and go from there. Then see if its worth tring to fab a truck re-pop vs. some blazer panels. It may not be all that bad and the blazer panels might be all ya need. Or you need core supports etc. Just hard to tell without pics. After the cut out shoot me some pics I would like to see what ya got going on ....later
07-17-2013, 04:17 PM | #3 |
Don't you need the rocker boxes?
07-17-2013, 09:24 PM | #4 |
on the truck pan you would have to cut the back of the pan and bend a lip that mounts to the back knee wall. the section behind the seats is longer on the truck pan.. Also cut out the hump and drill holes I think the pan is only 2wd
07-17-2013, 09:33 PM | #5 |
Ok, I was worried the truck pan wouldnt have been long enough behind the seats. Doesnt sound too bad then, except for saving the original rockers boxes and everything else underneath.
07-17-2013, 10:23 PM | #6 |
It is a bit tedious to bend the metal and get it straight but it is possible. How bad are the floors that you are consider the full floor. It might be easier in the long run to just do the patches.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
07-18-2013, 09:13 PM | #7 |
is any of this for sale? thanks
07-19-2013, 06:15 AM | #8 |
Ill try to stop by and get pics Saturday. Hes hard to catch at the shop, then I can getveveryvodys opinionson patching or replacing the whole pan.
07-19-2013, 08:59 AM | #9 |
Sounds good .....
07-20-2013, 02:15 PM | #10 |
Not able to post pics for some reason but anyways I've decided to replace the whole floor pan. Just need to find one close by so I dont have to ship it
07-20-2013, 08:36 PM | #11 | |
Tamraz has them in stock in Plainfield, they have at least 3 right now per their Ebay link. Pretty sure they let you come pick up as well, you might want to give them a call. http://www.ebay.com/itm/67-72-Chevy-...item5ae29ff5b9 Finally got new trailer plates today, so I will be calling you sometime next week to come pick the monster up. |
07-20-2013, 09:14 PM | #12 |
Thanks a lot Pat! Cant get much closer than that when youre in the sticks like me. Sounds good about this week. Im off mon tues weds and every eve except weds is good.
07-21-2013, 07:19 PM | #13 |
I am getting ready to do the same thing as yourself, I have purchased a two wheel drive floor pan and I will cut the back off to match up to the bed. I have also built a jig that mimic the body mounts from the frame. Presently I am rebuilding the bed, cut the last 6 inches of the rear bed, bought a patch piece from LMC and welded in place. There are a few more small patches to do, I wasn't able to find the cross sill that mates the bed to the floor pan, so I made one, fortunately there was enough of the old cross sill that I was able to duplicate. I am a little worried about cutting the pan to fit, but I cross that bridge when it comes. Good luck with your project
07-21-2013, 07:45 PM | #14 |
David623. Did the pan you bought have the lip already bent at the front edge that mates with the cowl part of the front floor. I have not seen a new pan.
07-22-2013, 10:33 AM | #15 |
Would I be better off getting a new pan with the bracing or without? Everything under the old pan is solid.
07-22-2013, 01:17 PM | #16 |
I would think it would be a whole lot less work, i dont think it was that much more money.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
07-22-2013, 02:57 PM | #17 |
What kind of bracing is the difference. I have always wondered. I am currently meshing a Arizona truck pan and patch panels I have cut probably 75% of my passenger side floor out. When I started this project several years ago the whole pan was not available. But I am still considering that option.
07-22-2013, 10:21 PM | #18 | |
My opinion? After i fooled with all the patch panels, i should have went with the full floor. Way less welding, and no one will be able tell that the floor was replaced. Weld it to the firewall, weld it to the bed bump up, weld to the toe kick, hang a couple rockers and youre done
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-22-2013 at 10:28 PM. |
07-22-2013, 10:31 PM | #19 |
Here is a shot of the bracing.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery Last edited by 69-72; 07-22-2013 at 10:53 PM. |
07-22-2013, 10:36 PM | #20 |
And here are some more of the rear lip for David
07-22-2013, 10:51 PM | #21 | |
I think if you left the original bracing in tact it would help with keeping things where they should be.
07-23-2013, 10:03 PM | #22 |
I just did a whole floor in mine, the original was pretty far gone. Here is my build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=545670
its a pain to do, but no way would I have done patches. |
07-23-2013, 10:16 PM | #23 |
bk04z66, thanks for your link to your build. My blazer is same color as yours. Im planning on the whole floor, just trying to find one close by to save truck freight.
07-23-2013, 10:46 PM | #24 |
Edit: meaning get the new pan with the bracing already installed
