Old 07-23-2013, 05:28 PM   #1
88fordf150
88fordf150's Avatar
Need To Remove The Dash From My Truck!
I need to remove my dash from my 69 to do a repair on the cowl area. Whats the best way to separate the dash from the lower window frame? It looks like it is spot welded together.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 07-23-2013, 05:40 PM   #2
mmiddle
mmiddle's Avatar
Re: Need To Remove The Dash From My Truck!
you can ether buy a spot weld cutter and cut these spot welds out or cut the dash where the dash pad is. It all depends on you.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 07-23-2013, 08:56 PM   #3
68gmsee
Active Member
68gmsee's Avatar
I think that cutting along the area below the dashpad and rewelding would be a better way. There are lots of spot welds there on the front. I'd be reluctant to cut them out for fear of introducing more openings for rust to set in after rewelding.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-23-2013, 09:06 PM   #4
mmiddle
mmiddle's Avatar
I do agree, if the top dash board does not need to move then just cut at the dotted line and reweld.
Mark
Jesus is the Way!
Old 07-24-2013, 05:03 AM   #5
88fordf150
88fordf150's Avatar
I agree, thanks for the idea!
Brad handshoe
