Old 07-26-2013, 08:29 PM   #1
tucsonjwt
Hood/cowl hinge pads
Does anyone know where to get these rubber/foam pads located at the bottom of the hinges on the cowl? Also, what is the foam pad between the fender and the cowl in the second pic? Is this part available also? GM part numbers would help. It looks like the part numbers have been superceded more than once. Thanks.
tucsonjwt is offline   Reply With Quote
Old 07-27-2013, 06:37 PM   #2
i heart square bodys
i heart square bodys's Avatar
Re: Hood/cowl hinge pads
i want to know where i can get the rubber pieces for the hinges too !
**BUMP**
1986 LWB c10 w/327 & vortec heads
i heart square bodys is offline   Reply With Quote
Old 07-27-2013, 09:00 PM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
LMC carries them
Malo83 is offline   Reply With Quote
Old 07-28-2013, 12:06 AM   #4
tucsonjwt
Can you tell me the LMC part number? I don't see them in the catalog. Thanks.
Old 07-28-2013, 12:59 AM   #5
tucsonjwt
OK. I see the parts in the online catalog now. They were not in my latest paper catalog from LMC.
Does anybody know about that foam cushion between the fender and the A pillar/cowl area? Is it an anti-squeak device or is it a water seal? This is the second pic in my original post.
Thanks.
Old 01-07-2014, 10:09 PM   #6
JointTech
JointTech's Avatar
part number? I dont see it.
Also there was a rubber pad about an inch thick and 3 inches long glued on the bottom of the cowl on both sides. I dont see that anywhere.
I cant wrap my brain around your picture. can you take one from farther away.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 01-08-2014, 05:32 AM   #7
TwinTurbo
TwinTurbo's Avatar
that foam is there to absorb water and cause a nice rust spot, most GM cars have them in and around the a pillars. I always remove those. Sure they are probably for some kind of noise or rattle issue but I'd rather have a rattle then rust
TwinTurbo is offline   Reply With Quote
Old 01-08-2014, 02:53 PM   #8
Squareforceone
Squareforceone's Avatar
did anyone else have trouble putting these pack on? Seems i stripped on side on mine like the screw holes got pulled up
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 01-09-2014, 12:35 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
I think your looking at this...was my 87
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-09-2014, 01:55 PM   #10
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Are they number 6 on 81-87 trucks?
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=33
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 01-09-2014, 03:36 PM   #11
TwinTurbo
TwinTurbo's Avatar
Yes, #6 in that catalog listing
