Old 07-28-2013, 09:51 PM   #1
c10 custom
turbo 350 to 700 r4
hi guys i own a 1968 chev truck and i am wanting to convert the turbo 350 to a 700 r4 the truck has a two piece driveshaft i was wondering do i have to change the tailshaft on the 700 r4 to fit for the two piece driveshaft any help would be great thank you
c10 custom is offline   Reply With Quote
Old 07-28-2013, 10:02 PM   #2
Rod Bender
Re: turbo 350 to 700 r4
I'm in the process of doing the same on my '70. I have a turbo 350 with a long tail shaft housing, after measuring everything it looks like my driveshaft is going to work. ( I had shortened it previously, when I changed the transmission to the long tail shaft ) The 700R4 transmission tails haft will work but you may have to short your driveshaft.
Rod Bender is offline   Reply With Quote
Old 07-28-2013, 10:55 PM   #3
Chvy2NV
Subd...
Chvy2NV is offline   Reply With Quote
Old 07-29-2013, 11:29 AM   #4
Dova
Dova's Avatar
I'm sure someone else will chime in. But the long tailshaft on the 350 should be about 6" if it's the short tail shaft you'll have to shorten your driveshaft by 3" or so. Measure twice and have it made once. Perfect time to go to a one piece drive shaft.
Dova is offline   Reply With Quote
Old 07-29-2013, 04:54 PM   #5
HSRACER
HSRACER's Avatar
I have been told that a long tails haft 350 will be a direct fit except moving the trans mount back a little. I have a 700 on my bench to put in my 69 in the next couple of weeks. I will let you know how that turns out if you are not in a big hurry.
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 07-29-2013, 07:55 PM   #6
c10 custom
yes please let me know how the swap goes HSRACER thank you
