Old 07-30-2013, 09:47 PM   #1
robber grin
Front disk brake hose
I am trying to figure out my front disk brake hoses - need a picture of 78 1/2 ton style installed - PLEASE!
Bob
robber grin is offline   Reply With Quote
Old 07-31-2013, 07:35 AM   #2
robber grin
Re: Front disk brake hose
Maybe I didn't word that correctly - I'll try this one more time... I'm also aware from the polls and responses that 62's are maybe not that common to these parts as one might think.
I'm in the process of mounting 78 1/2 disk brake hoses on a 1962 C10 chassis that has the 78 front crossmember installed.
As Mark (or any of you 60-62 X-men and ladies) are well aware the frame is boxed at the point where the hose comes over and is usually attached with the stamped hex-nut.
I saw Mark's solution and I know that will work - I'm just trying to see if there might be options to the hard line and hose junction being INSIDE the boxed area of the frame.
ANY pictures that might elaborate on "the most intense stand-off in the history of my truck's build" will be appreciated by the old hack (me) who has to figure it out today.
Blessings & peace,
Bob
Old 08-01-2013, 08:05 AM   #3
robber grin
In case anyone else can't figure out how to do this - here's one possible fix.
I bought these from Speedway and welded them to the bottom of the frame just ahead of the crossmember.
Moving on -
rg
Old 08-01-2013, 10:05 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
The brackets you bought are what I would have done.
Please post pics when you get time.
Keith
Convert to disc brakes.
Old 08-01-2013, 04:11 PM   #5
wayno
went with a porterbuilt front member going through the same thing right now... well that and bending new hard lines - if I get to it before you do I will share how I solved it. Good luck.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 08-07-2013, 07:31 AM   #6
robber grin
Here's a pic of the Speedway tab welded to the frame just ahead of the crossmember.
Thanks guys -
bob
Old 08-07-2013, 07:33 AM   #7
robber grin
Driver's side - same~same...
Old 08-07-2013, 07:38 AM   #8
scottofksu
scottofksu's Avatar
Nicely done RG!
I'm sorry the community left you to figure this one out on your own. Thank you for posting this information for the collective good!
P.S. What does Speedway call those? Found it!
http://www.speedwaymotors.com/Remova...ose,45896.html
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 08-07-2013, 08:08 AM   #9
robber grin
Speedway "Removable Brake Tab for Rubber Hose"
Price: $9.99 PR - In Stock, Item #: 91031311
