Old 08-01-2013, 12:50 AM   #1
Chevys10dr
Chevys10dr's Avatar
Picks of stock retracting seat belt installed
Ran into a lil issue with the installation of a factory set of retracting lap belts, when I install them the lean into the door when it is closed, there is only 1 mounting hole in the floor to install, is the mounting hole the same as the shoulder belt mount?
Chevys10dr is offline   Reply With Quote
Old 08-01-2013, 08:41 PM   #2
Chevys10dr
Chevys10dr's Avatar
Re: Picks of stock retracting seat belt installed
Anyone?
Old 08-01-2013, 08:45 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Here's an old one that I have. I'll look to see if I have others. And, if you need a particular pic I can get you one tomorrow.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-01-2013, 08:57 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Here's another one I found.
06 Trailblazer
Old 08-01-2013, 09:03 PM   #5
leddzepp
Moderator
leddzepp's Avatar
If your truck is a 67, both the floor and shoulder mounts use a 7/16- 20 bolt (fine thread) 68-72 trucks use a 1/2- 18 bolt (course thread) for the floor mounts. All 67-72 trucks use a 7/16- 20 for the shoulder mounts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-02-2013, 12:34 AM   #6
Chevys10dr
Chevys10dr's Avatar
Thanks 68gmsee, mine looks to mount the same spot but it leans on a 60-70 degree angle towards the door I will post a pick later.
Old 08-02-2013, 12:35 AM   #7
oklalawnboy
oklalawnboy's Avatar
They do have a little bend to them. Maybe you have the left and right switched. My 2 cents.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
