speedometer on ls swap
What are u guys running for a speedometer? I kinda wanted to keep my original 100 mph speedometer. i'm considering goin aftermarket...is there a cheap one I can go with? those Dakota digital gauges are so pricey man.
Fabricate till you "puke"
Re: speedometer on ls swap
Do we really need a speedo? I look at it like this...somebody runs into the back of me, I guess I was not driving fast enough!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
i'll be swappin a 99 Silverado 5.3/4l60 in my 74 chevy.
meowMEOWmeowMEOW
It'll take a cableX if you want to run a gear driven speedo on an ls swap. Otherwise any electric speedo you can find would work. You can even just use a gps if your in a pinch for a short time while finding a more elegant solution.
I chose to make the tach the centerpiece of my dash, so my speedo is a function of the Scangauge II that I have. It small and runs off the ECM, has like 50 functions, one of which is speedo. The display is not large, and is digital only, but its plenty readable from where I sit, and since it can display other stuff and scan the ecm, its a swiss army knife in the cab. take a look at the "testing lights " video I posted in my build, it shows the scangauge at night, and I have some pictures of it on the dash in the build as well.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#5 | |
Slots go on anything!
I am going with a 90-91 R cluster. It looks fairly original.
1974 Jimmy- 5.3/4L80e/NP241 |
I just used an electric AutoMeter speedo. It was the easiest for me at the time
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
If you want to keep the original look, check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=512751 There's quite a few of us going with this option.
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
For the square body trucks most guys are using a cluster out of a 90-91 Blazer or Suburban. It has electric speedo and is a direct bolt in, the thing I don't like about it is that it only goes to 85 mph. I am currently working on a 120 mph speedo with tach for mine, using gauges from a 2000 Hyundai Sonata.
yeah that's why I didn't want to go with the burb cluster too..i wanted to keep my 100mph speedo....maybe ill just have to suck it up and get it until I can get an autometer speedo.
I have all elec. auto meter gauges, bought them all individually....used my gps as the speedo till I could afford the auto meter unit. set on 6cyl. check these guys out....http://www.classicdash.com/shopping/...87/Auto-Meter/
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#13 |
so I decided just to go with the cable x set up...its about $300 so not too bad...i'll just use my tom tom until I can afford it.
#14 |
I've got a slightly used cable-x I would sell. $250 shipped and it's yours.
#15 |
im interested but have no cash right now...i'll let u kno when I have the cash...hope u still have it by then lol
#16 |
How slightly used is it ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#17 |
If I didn't tell you it was used you wouldn't know it.
#18 |
Did you use something different?
#19 |
I'm going to do the electronic conversion that LS1Nova71 came up with this winter.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
